Just wondering if anyone has a "good" condition starter motor for 4.0 motor want to sell?
1995 XJ starter motor
Want2Retire
- Bush Crasher
CRAZYBUSTARD
- Bush Crasher
Re: 1995 XJ starter motor
only $250 to $400 for a new one depends wat you want
Want2Retire
- Bush Crasher
Where would I order one? I asked repco here in Rotorua and was told they don't know. Seen one on trademe but surely there must be somewhere that sells them?
http://www.panpacific.net.nz/front/home
Or one online from the states.
Also check you inhibitor switch on the g.box as these car play up over time with nothing there when the key is turned.
JK Wrangler 35s.
ebay usa ,,got one 170 odd kiwi landed here ..took 10 to 14 days or heaps of the pigs getting parted out on tm, or rebuild yours ..not much to it
v8 tj...luvs the gas......
Want2Retire
- Bush Crasher
Cheers guys, I'll check them out. Thought I had a flat battery at first, charged overnight, still really slow turnover, got a new battery and exactly the same thing. Chucked multimeter on new battery and is good so to the alternator (14.7v).
Unless I'm missing something else?
Thanks
Thanks
Try this guy,i bought starter off him for my wrangler couple days ago for $150,bloody good to deal with & a Jeep nut, said he had heaps of parts or can get...think he is a wrecker in Palmerston North,not sure of his name as i just put wanted on trademe & he txted.....
his number is....0212694430....
Want2Retire
- Bush Crasher
Cheers furnace. I am going to take starter motor out tomorrow and see if anything obvious, give it a clean and de-mud it. If no luck, then will order another.
Thanks
Grant
Thanks
Grant
hate to barge in. my starter in my TJ has been playingup. I had a look thru your link here and within a hour the starter has come out,been cleaned and replaced. Is now working good as. thanks heaps for the link. helped lots. cheers Russty
