Hi, any one have a diagram of link to one for LN106R electrical? Looking in particular for alternator wiring.
W
WTD: LN106R 3L wiring diagram
- williamhamilton
Re: WTD: LN106R 3L wiring diagram
I have two manuals for the hilux, if you get stuck pm me and I'll take some photos of it
- evolution02
Alternator wiring is pretty simple. Most probably has external regulator. 3 pin plug on alt is field, earth and N which go to the regulator
- williamhamilton
Thanks guys, I was hoping to match colours rather than tracing wires - to source.
Lux plug-
_____
|Black|
|Blue | Green|
Alt plug of a different style
_____
|Blue|
|White | Red|
Lux plug-
_____
|Black|
|Blue | Green|
_____
|Blue|
|White | Red|
- evolution02
Ok sounds like your alternator with blue, white & red will be an internal regulator version. If you look at the bolt on plate where the battery stud is the internal reg version will have a lump in this plate to accommodate the regulator.
You can fit this but would need to remove the regulator on the drivers inner guard and link the correct pins. The plugs on the alternator will also be a different style and won't plug in(for safety). Would need to change the vehicle side plug to match
Why not just get original alt repaired?
