Winching with tie downs....
All aspects of safety with 4wds from proper mounting of tow hooks to recovery situations.
mumbls
Post by mumbls »
edit title n/plates
drinking hatorgade
jervisad
Re: Winching with tie downs....
Post by jervisad »
i guess it would work but it wouldnt be very safe would it?? and wouldnt it be real hard to crank it up aswell??
mudlva
Post by mudlva »
no issues with safety as what could happen? it would just still be stuck.
use a short lenght of wood in the handle to help increase leverage
I've removed many a vehicle (including a 3t truck stuck in the back of a rest area in the kangahake gorge :oops: :oops: :shock: ) with truck tie downs, and pulled 4x4s that have slipped one wheel off a bank back to safety as well.
just have to use a bit of common sense, thats all
CRAZYBUSTARD
Post by CRAZYBUSTARD »
some company makes handles for truck drivers that fit into the ratche handle can get lots of leaverage
evolution02
Post by evolution02 »
CRAZYBUSTARD wrote:some company makes handles for truck drivers that fit into the ratche handle can get lots of leaverage
The extension handles are normally for the chain tie downs on truck
Using strops should work fine, 2 would be better to hold while you reposition
Return to “4wd Safety”
