holden 3.8 v6 fuel consumption
Posted: Mon Apr 22, 2013 6:50 am
by 85bj71
Hi im running a 3.8v6 in a suzuki vitara on 35s, $100 fill (full tank) will get between 200-250km depending on how heavy my foot is.
its stopping me from using my 4wd as it is so expensive to run, Im thinking of upgrading the ecu to one of these
http://www.trademe.co.nz/motors/car-par ... 636811.htmbut rather would rather look into a diesel swap if im going to be wasting my time
Who else runs a 3.8 v6 ? what sort of economy do you get?
Re: holden 3.8 v6 fuel consumption
Posted: Mon Apr 22, 2013 7:21 am
by Crash bandicoot
so at the moment assuming the price of fuel is $2.09 you are looking at just under 48 litres. The wifes VY averages around 9.8 litres per hundred kms on the open road and 10.4-11 around town...
assuming you gearbox allows you to do 100 kph at around 1800 rpm this is what you should get.
Posted: Mon Apr 22, 2013 7:33 am
by tow99
Which comodore motor and ecu are you using? I just drove my ecotec vs manual to Auckland and back on about 150 ltrs.
Posted: Mon Apr 22, 2013 7:41 am
by mudlva
Posted: Mon Apr 22, 2013 7:44 am
by oldyella
Na your wifes vy is not turning 35's mate. I would think acceptable fuel consumption might very between 13 to 15 litres per 100km on a good day. Also depends how much tread your 35" tyres have. Before spending any dollars. Do some basic checks like plug colour. Air filter clean. If it is only a slight problem. Get an air / fuel ratio sensor stuck up the tail pipe by your local dyno / vehicle tune place. Im hoping to get under 15 litres per 100km in my rover v8 running new 32" tyres.
Posted: Mon Apr 22, 2013 10:24 am
by Crash bandicoot
oldyella wrote:Na your wifes vy is not turning 35's mate. I would think acceptable fuel consumption might very between 13 to 15 litres per 100km on a good day. Also depends how much tread your 35" tyres have. Before spending any dollars. Do some basic checks like plug colour. Air filter clean. If it is only a slight problem. Get an air / fuel ratio sensor stuck up the tail pipe by your local dyno / vehicle tune place. Im hoping to get under 15 litres per 100km in my rover v8 running new 32" tyres.
agreed.
Posted: Mon Apr 22, 2013 10:31 am
by Petemcc
yea way more likely that your ecu is not making it use more fuel but it's what it's pushing and the revs you are pulling as well.
As Pete said get the air fuel ratio looked at if you can then you will know where to spend the money.
Posted: Mon Apr 22, 2013 4:59 pm
by 85bj71
tow99 wrote:Which comodore motor and ecu are you using? I just drove my ecotec vs manual to Auckland and back on about 150 ltrs.
89-92 model commodore engine and ecu with 4 speed auto, 4.1 diffs and 35's
im getting around 20-25L to 100km so it is bad
cheers for the advice, Ill start with the hose up the tailpipe and see if it is running rich then go from there!
Posted: Mon Apr 22, 2013 5:39 pm
by tow99
I would try a plugin memcal before swapping ecus.there's a guy on trademe selling them and it made a noticeable difference in my commodore.if it was running that rich you would see it black smoking under load.how many ks has the motor done?
Posted: Mon Jul 08, 2013 8:02 pm
by Pico42
This thread on Auszookers went into a lot of detail on getting the 3.8 to run well in a Vitara.
http://www.auszookers.com/forum/viewtop ... =4&t=30857
Posted: Mon Jul 08, 2013 8:59 pm
by Ashohman
also what ratios are u running cos I know the 3.8 ecotecs like to cruze at 2k rev @ 100kms and if you got a non ecotec 3.8 well they are just plain thirsty haha. I get 400km out of myn its in a 86 pickup hilux 31's n 4.88's atm also gota make sure u got all the sensors n dat hooked up and they are running correctly so it doesn't go into limp mode and churn threw the gas.
Posted: Thu Jul 11, 2013 5:25 pm
by slidenyo
I dare say its ^ in limp,
clear all the codes from the ecu an see what pops up,
have you still got the service loop in your loom?
if you haven't it may be a bit tricky.
I assume its a series 2 non ecotec from a vs
which should pull 12-14l per 100 openroad
Posted: Thu Jul 11, 2013 5:48 pm
by shortylux
My VP V6 Hilux with 4.8s, beadlocked 35" Simex and an after market memcal did betwen 5-7 ks per litre. Which is 15-20l per 100k.
I don't really have open road figures for you as it only ever did open road stuff followed by a day of low range thrashing.
