XJ Guard Cut / flares on a tightish budget
waza4x4toy
Post by waza4x4toy »
Ok need advise im going to 32x12.5x15s on an 95 XJ, no going back now just going to do it and make it work. My regret, could have been a lots easier going to 31s but after having to be dragged on my diffs so many times of late with my current 30x9.5x15, i wanted to go bigger....seems to be common story on here
So far have about 3" lift happening all works good
First issue with 32s not enough back spacing on standard rims test show they are real tight on rear so will need some rims ....see other post (WTB). So will have some nicely painted black factory rims for sale soon now!
Back spacing on XJs, there seems to be lots of ideas on forums just want to make the right descison, Warren at 4wdbits very helpful today but want to get more input if i can.
Any advice or pictures about guard cutting would be most appreciated.
Want it to look good and be functional but cant afford to spend dollars on new bushwacker guards......well not if tyres and now rims are needed its gonna come close to divorce! Not sure on raising the XJ factory flares unless someone can show me it done well.
Like to check out anyone else in aucklands XJ that might have gone before me and fitted TJ guards or rubber flares if your keen for a newbie to have a look see
Any good relevant post links would be apreciated also
waza
WRNGLR
Re: XJ Guard Cut / flares on a tightish budget
Post by WRNGLR »
I have some pocket style flares I was going to put on my TJ, have decided on something different, will take some pics for ya tomorrow ( am at work tonight) and you can see if they'll do the job.
PM me if keen and we'll talk $
yeti
Bruiser
Post by yeti »
post a couple of links for ya in a couple of days ..busy at mo working on my pig.... :wink:
v8 tj...luvs the gas......
phraza
Post by phraza »
2WD 06 Hilux... for now
waza4x4toy
Thanks for info so far and considering all options if anyone has a XJ in auckland that has chopped guards would be great to see it for further advice.
XJCrawler
Post by XJCrawler »
This is probably a handy guide since you're on a budget. Reusing your stock flares may be your better option.
http://www.yuccaman.com/jeep/trim.html
http://www.yuccaman.com/jeep/reartrim.html
waza4x4toy
Great thanks for link this looks to be one of the better how to links I have seen so appreciate the reply
Jeep been parked up for a while as have other jobs on so have started back on this and will see how it turns out, did like the TJ flare fitments I have seen driving around here in Auckland and on links so that is a good option also.
yeti
Bruiser
Post by yeti »
just watch when cutting rear .........tis a piece of piss to do,....
http://www.offroadexpress.co.nz/Forums/ ... 0&start=45
waza4x4toy
yep ta Yeti understand the joining skins issue and will be careful to avoid cutting open the rear in the process!
Return to “Jeep”
