How do I adjust the height on the front of a d21
My torsion bars are currently wound up. I want to bring the height down to standard height. Any info ASAP would be awesome! Cheers
Re: How do I adjust the height on the front of a d21
if they are wound up and you want to bring it back down to standard then wouldnt you just wind them down??
do you know how to do this?
Thanks for the reply. I bought the truck with it wound up. I have broken s*** loads of tie rods. I just want to get it back down to standard height to reduce the chance of it happening again! But no sorry I don't know how to wind them back down!
at the end off the torison (near end off transfer case) will be two long bolts and two nuts on each bolt. you want to undo the nuts
when you get your height ur after lock the nuts against each other
good tip to do is measure the height it currently stands at each side then drop it the same amount off cm/mm on each side
in failing this, take it to your local garage
another d21 terrano
ex lancer build
ex lancer build
Thank you, will post to let u know how I get on cheers!
fullthrottle
- Shuttle Queen
Hey Josh
This link may help.
http://www.offroadexpress.co.nz/Forums/ ... 25&t=29240
Just in reverse of course. Just check underneath, in the crossmember are the adjuster arms that have some long adjuster bolts that pass up through the cross member. See how much thread you have to play with.
They could have been re-indexed and if not done right you might need to undo the indexing also.
This link may help.
