D21 transfer case
Posted: Wed Apr 24, 2013 8:11 pm
by joshpom
Is it very difficult to replace transfer case, anyone done it and could give me info on it!? Thanks
Re: D21 transfer case
Posted: Wed Apr 24, 2013 9:01 pm
by will i am
i dont no what the autos are like, but ive rebuilt a couple off these manual gboxs with new bearings
ive never done it in place
if you were trying to do it in place you would need to:
-unwind torsions then remove
-remove driveshafts
-take gearstick and 4wd shifter out
-undo plugs on transfercase
- at this stage i would drop gearbox and transfer case oil
-crack off bolts that hold transfer to gbox
-slightly drop down gbox
-undo bolts that are cracked off and remove transfer
you will need a hoist and trans jack to do it this way
Posted: Fri Apr 26, 2013 1:12 pm
by joshpom
i got the transfer case out, and noticed that my new one is a different size, the shaft from the gear box to the trasfer case is small, where as the hole for it to go in on the new transfer case is bigger than the old one.?
Posted: Fri Apr 26, 2013 2:24 pm
by lax2wlg
V6 Transfer case had larger drive chain and different output spline count. Talk to kbjj, apparently pretty easy to make it work. Cool mod.
edit: that's input spline.
Posted: Fri Apr 26, 2013 3:09 pm
by Dirtydog
Otherwise ive got mine that came out of a td27t auto, if your interested.
Posted: Sat Apr 27, 2013 11:23 pm
by kbjj
lax2wlg wrote:V6 Transfer case had larger drive chain and different output spline count. Talk to kbjj, apparently pretty easy to make it work. Cool mod.
Strip both transfer cases and swap the input gear, autos have a bigger input shaft than the manuels. The v6 auto transfer case I got has a bigger drive chain in it.
Posted: Sat May 11, 2013 11:00 am
by kiwinoz
Would the trans case in the Mistral have the bigger chain? Shaft?
And would the auto and manual be the same?
