April 27/28th
andy3542
April 27/28th
Post by andy3542 »
Ill start this one.
Finished the new rear bar on the safari. :D
hoping to get back into the landrover in the next couple weeks now my bits from the states have arrived.
Offroad Addiction TV
muddyplumber
Spring Free
Re: April 27/28th
Post by muddyplumber »
Sanded the exo back and repainted.Now working on fixing rear wheel bearings that blow out.Dusted off the 1kz and starting to clean it up.
Filthy4x4
Re: April 27/28th
Post by Filthy4x4 »
Well looks like I may have added another Nissan to the stables...
Picked up a Terrano off a mate for a daily, now to sort the steering and get it inhaling some decent boost 8)
027 MUD GEAR - (027 683 4327)
Check our facebook:
firestonecruiser
Re: April 27/28th
Post by firestonecruiser »
flushed out heater lines as heater hoses were getting hard. cleaned hoses out and removed crud that was in there. 1 heater hose is perished and so went to repco and did a search no inlet or outlet heater hoses in there stores throughout country. will have to get directly fron gates in aus. have just had rad rod n flushed to. so if anyone got heater hoses for a 91 80 series that i can buy would be great.
cheers jono
Dozr
Stropper
Re: April 27/28th
Post by Dozr »
muddyplumber wrote:Image
Nice looking exo mate, big thumbs up!
Custom Performance Racing
https://www.facebook.com/CPRNZLTD
zukmeista
Re: April 27/28th
Post by zukmeista »
Trimmed front guards and fitted 33's, just need to do flares now.
evolution02
Re: April 27/28th
Post by evolution02 »
firestonecruiser wrote:flushed out heater lines as heater hoses were getting hard. cleaned hoses out and removed crud that was in there. 1 heater hose is perished and so went to repco and did a search no inlet or outlet heater hoses in there stores throughout country. will have to get directly fron gates in aus. have just had rad rod n flushed to. so if anyone got heater hoses for a 91 80 series that i can buy would be great.
cheers jono
You could try terrain tamer, pretty sure they do them in sets
RichardM
Newbie
Newbie
Re: April 27/28th
Post by RichardM »
Got stuck at woodhill 4 a while yestetday now i gotta major oil leak lol and water got inside the truck for the first time ever. Was a good day!.
Cameron
Re: April 27/28th
Post by Cameron »
cheers jono
tried genuine? heaps of toyota stuff is soooo cheap it's ridiculous. (genuine parts in general can be surprisingly well priced.
firestonecruiser
Re: April 27/28th
Cameron wrote:
cheers jono
yeah i have toyota wanted $180
motardbiker
Re: April 27/28th
Post by motardbiker »
New 4 inch lift and 35"s all locked and loaded, managed a short little play up thompsons track, minimal rubbing, stoked as!
Re: April 27/28th
RichardM wrote:Got stuck at woodhill 4 a while yestetday now i gotta major oil leak lol and water got inside the truck for the first time ever. Was a good day!.
pulled newish hilux out of there this arvo, then back after 4,30pm to remove a safari from that hole too
new tyres were good
micahb
Re: April 27/28th
Post by micahb »
finally done my swivel hub rebuild and swapped from lekky to manual hubs, used hubs and stubs from another cruiser. what an arse of a messy job. those axle seals were toasted so it was all goop. diff oil was lumpy. haha. all clean now. all new brakes too. just need to bleed brakes tomorrow night and it done. to get the right preload on the swivel bearings, ended up with a .10 shim on the bottom and no shim on the top. couldn't find 2x .05 shims. or anyone with any.
parker
Re: April 27/28th
Post by parker »
Got the head back on the 40 ........... running much nicer now
catalystracing
Re: April 27/28th
Post by catalystracing »
Gave the Lux a birthday and cleaned it :shock: Removed door skins and lubed all window tracks and tightened bits where needed. Got a fright this morning when I looked in the drive and wondered whose the new truck was.... :lol:
drive it ...
Re: April 27/28th
Post by drive it ... »
Made the truck lighter - burned a winch in the teams comp at Oxford so thats 40kg off the front, then went to tighten the sway bars (the bolts always work loose) but found the whole bracket had torn off this time. So stuff it, I can wobble a bit more down the road, off came both sway bars for another 20kg saving. Should get an eco friendly award now, being lighter I'll burn less diesel. :lol:
