3Y ENGINE is it really that bad?
Hi guys,
I'm looking at getting a petrol hilux running a 3y big change from the 3.0 turbo diesel navara.
How bad does the 3y perform? Will it cruise at 100km/hr? Also how does it go in low ratio off road? Are they worth looking at or should they just be avoided? Thanks in advance.
Re: 3Y ENGINE is it really that bad?
I have had a surf auto with one, was a thirsty beast but adequate off road, just make sure your on top of gear changes on sand/beachs.
never missed a beat that i can remember, just had a small oil leak from the main seal
DIRTY OLD HILUX
022 519 7700
022 519 7700
They are gutless and hugely thirsty, but generally bulletproof. I wouldn't waste my time with one unless purchase is very cheap and a repower is an option.
Cheers guys. Yeah repower is an option but not straight away. For a 1UZ conversion into a YN65 what sort of cost, 4000ish?
$4-5000 if you do it yourself. Get mates to do perks etc.
solid and bulletproof, and will happily rev its tits off all day in 2nd low on 33s
shite in sand
shite in sand
Yeah I'd be doing it myself are there any other cheaper conversions that are worth it?
I presume a 3y wouldn't like 35s?
3rz-fe. toyotas 2.7 twin cam motor found in hilux's 1996 onwards.
they will bolt straight up to ur gearbox
J_Dub wrote:3rz-fe. toyotas 2.7 twin cam motor found in hilux's 1996 onwards.
I shall look in to that. Cheers
Not bad at all, i bought one a while back, it went really well. Was going to re-power but never needed to. the injected model has the same output as the 2.4d (2L) but much nicer to drive, i was doing heaps of kms and getting 10l/100km open road with 31" muddies, definitely no probs offroad. Will need to be re-geard for 35's, mine didnt mind the 33's but fuel economy suffered
92 LWB Safari TD42
i had a 3y in my truck was a bit sluggish but still kept up offroad and got you there onroad if in no rush have just dropped a brand new 4y in with a weber 32/36 carb is quite surprizing the notice in power increase
The particular truck I'm looking at is on 35s but comes with a set of 32s. What diffs could you put in it to run 35s? As aren't the standard petrol ones 4.88s?
X2 as soon as my new clutch arrives Im going to put one in my 85 yn60 surf, With a body lift it will apparently bolt straight in then just have the fuel and elecrics to sort am hoping to get a build thread going once things are underway.
Thanks Stu
Had a 3RZ in my other hilux. Bloody great motor. Torquey as hell down low and they love to rev while sounding superb too! I would consider this engine for a repower as opposed to the 1UZ. With aftermarket gear on them, crazy power can be made with these donks.
Toyhatsu Bitsalux
oompalompa
- Newbie
What sort of mileage do you get out of them. Do they reach the half million km like the 2.8 diesels? When you say they are lacking on sand , is that at speed or chugging along first low. I am looking and changing from 3.1td bighorn to a 2 l petrol hilux. I know it will be a lot different but how much
Having driven both and currently owning a 3.1TD Bighorn on 33's the power output of the diesel is a lot better, especially the torque. With bigger tires on the beach the 3Y will struggle.
I guess it all comes down to what you are going to do with it and how and where you want to drive it. At the end of the day no one ever complained about having too much power though!
The 3Y is a reliable motor but as already mentioned pretty gutless and a bit thirsty. I would take a 2.4TD Surf/Hilux over a 3Y.
Matt.
Matt.
oompalompa
- Newbie
Cheers For that. Really starting to go off them now. Ruc and reg are just so dam expensive for a truck I don't use much and looking for a flat deck
