Clutch plate replacement help toyota surf
stackd
Post by stackd »
Hay all im in need of changing clutch as warn out but want to learn to do it.
is there anyone here that would be able to help me out and teach me the ins and out happy to pay cash but just wand help. so if you have the time to change clutch and teach me would be stoked it a 91 surf 2.4 as ive just moved to welly dont have access to a workshop but have basic tools with me. thanks for your time
rob
tweake
Re: Clutch plate replacement help toyota surf
Post by tweake »
have you got the replacement parts sorted?
do you know if it still has original clutch?
if you replace it with original dual mass type clutch its something like $2k for the clutch set. cheaper and more reliable to convert it to single mass. need hilux flywheel and a different pressure plate. specs are on surf site.
stackd
Post by stackd »
Yea clutch set up is standerd havent got any replacement parts yet was going to replace with the same as is there
tweake
Post by tweake »
stackd wrote:Yea clutch set up is standerd havent got any replacement parts yet was going to replace with the same as is there
stackd
Post by stackd »
So whats recomended as a replacement
85bj71
Post by 85bj71 »
tweake wrote: cheaper and more reliable to convert it to single mass. need hilux flywheel and a different pressure plate. specs are on surf site.
85bj71
Post by 85bj71 »
:roll:
tweake
Post by tweake »
:lol:
Roenut
Post by Roenut »
Did they all come out with dual mass on the 2.4s? I'm sure there was factory solid flywheel ones. :?:
Less Traction More Action!
previous vehicles - commodores, bmws, subarus, 1kz surf, d21 terrano.
ln60 surf, current - kzn130 surf
tweake
Post by tweake »
Roenut wrote:Did they all come out with dual mass on the 2.4s? I'm sure there was factory solid flywheel ones. :?:
all 2lt are dual mass afaik. but i think 2l are single mass but clutch is a bit of a different size.
when i build the old surf 2lt motor out someone had fitted what i think is a 2l clutch setup. but there was a mismatch in size and it was stuffed.
luckyme
Post by luckyme »
tweake wrote:...original dual mass type clutch its something like $2k for the clutch set
:shock: wow... feel lucky now that never had issues with clutch on my surf. whats in that 2k?
Roenut
Post by Roenut »
Cover, plate, release bearing and a fookin expensive new dual mass flywheel.
Dual mass flywheels are non serviceable items (cant machine/rebuild them)
stackd
Post by stackd »
Thanks for the advice doing a single mass convy $1200 fitted so not to bad
tweake
Post by tweake »
8)
only thing is sometimes they make a bit more noise and vibration at idle.
the dual mass is there to dampen noise and vibration.
stackd
Post by stackd »
Well had single mass done cost was $890 cheaper than first quote not bad on noise but seems lighter on the clutch pedal don't have to stomp on it 10 points for handling works great an heaps of grab
tweake
Post by tweake »
they got the engage height about right? ie you don't have to push it right to the floor?
Return to “Tool Shed”
