35/11.5/15 Simex tyres fit on 8" or 10" rims
Hey guys,i brought a set of simex tyres on rims they on 8" rims but wrong off set for my truck, it recommends to fit on 9" rims written on tyres, ive got 8" and 10" rims in right offset which am I better 2 use,cheers hamish
- skid
- Tyre Man
Re: 35/11.5/15 Simex tyres fit on 8" or 10" rims
8"
legally you need 9 inch rims if it specifies it.
as for the better choice 8 inch by far, even 7 is better again. poor man's bead lock
- drive it ...
10" rims look cool but not enough side pressure on beads, if you drop below about 15psi off road you'll start popping tyres in ruts. I'm running 10.5" simex on 7" rims and they are fine so your 11.5s on 8" rims should be sweet.
I also run 12.5" BFG MT's on alloy 7" as well, the BFG's are a bit wallowy on the road unless you keep them pumped hard, and then they round out a bit and wear in the center.
Cool cheers for fast repley.
Hey, I got a set on 12.5 creppies on 10" rims never had a flat or had one come off a rim, they just getting a little low tread and sore these simex 4sale, and thought id give them a go
Anyone one know wat offset the other rims would be they 8" but their more rim a back than my -19 offset rims , couldn't find any thing on rims anywhere just roh trax2
- skid
- Tyre Man
hamish4x4 wrote:Anyone one know wat offset the other rims would be they 8" but their more rim a back than my -19 offset rims , couldn't find any thing on rims anywhere just roh trax2
-22
- drive it ...
Measure backspacing = wheel flange to edge of rims.
Measure rim width and split in half to get center measurement
The difference between backspacing and center is the offset. If its closer to the hub (wheel sticks out further) its negative offset.
Or just ask on ORE and someone will know.
