Wheel hitting radius arm
Posted: Fri May 10, 2013 10:42 pm
by tafftunk
Probably a dumb question new to all this nissan stuff but my drivers side tyre rubs on my radius arm on my gq safari on full lock only on that side not the passenger side I have a 60mm lift and 35s with front and rear guard chop and this is the only place I get tyre rub any help would be awesome thanks
Re: Wheel hitting radius arm
Posted: Fri May 10, 2013 10:47 pm
by jonossiksilvia
just adjust the steering stop on that wheel slightly until it stops rubing
Posted: Sat May 11, 2013 7:20 am
by Twodiffs
Yep...plus check the steering stop bolt is still there, they are known to come loose and fall out. If so a good hex bolt will work as replacement with a locking nut for adjustment.
Posted: Sat May 11, 2013 7:28 am
by tafftunk
Oh sweet cheers guys thats awesome now to attack the dreaded long bolt on the thermostat, the water temp needle is only just above the cold mark thermostat must be stuck open hope that's the only problem and pray to the nissan gods the long bolt comes out as one piece wish me luck
Posted: Sat May 11, 2013 8:28 am
by klompy
I found on mine with 35s they are just to fat and need a different off set rim to move the whole tyre/wheel thing out a bit.
Posted: Sat May 11, 2013 10:00 am
by tafftunk
I've got -22 offset rims and its only hitting on the drivers side had a look for the little stoppers but can't see them or weather there was any there in the first place
Posted: Sat May 11, 2013 9:30 pm
by motardbiker
tafftunk wrote:...... now to attack the dreaded long bolt on the thermostat......
Give the head of the bolt a few good hits with a small hammer, if you cant get a clean hit on the head of the bolt, use a pin punch, this will usually 'shock' the threads and loosen the rust and crap etc
Posted: Sat May 11, 2013 9:56 pm
by tafftunk
Cool thanks for that it worked a treat massive and the truck works mint with a new thermostat, Now to replace panhard bushs then the truck is ready for hammering some mud
