leaf spring hilux/surf chassis has been stripped down and re-sprayed.
shackle/spring lift (hard to say exactly how much lift but guessing 2.5"-3")
4.88 diffs (should turn 35's easy
2" body lift
Removable top (LN61) with roof racks
Sun roof.
Newer CT20 turbo, some seals done on fuel pump,
just done rocker cover seal, cambelt, water pump, tensioner, idler, aux belts, front main seals while i was there
Asking $5,000.
Looking to change to 70s LWB prado as family is getting to big and no longer fits in the 2 door
Couple of bad things (mainly cosmetic), Has a bit of paint fade and a couple of small dings.
Has 33' muds on 15x8 steels but are pretty worn.
