Weird problem?.. D21
For all Nissan related topics
BogBoy
Post by BogBoy »
Ok so my engine has a rattle to it even after doing the lifters. Seems to be lacking power as well.
Some times it will stop its rattle and gain power.....
Worn lifters? Or worn push rods?
I was thinking that it could be a worn point on the push rod head and when it spins/rattles around to another point it might take up the space and stop the rattle, which in turn could make the valves open the right distance and gain power.
What are my options as I have a trip coming up that I want the 4wd sorted for.
rokhound
Re: Weird problem?.. D21
Post by rokhound »
Cam lobes? A lot of older Nissans had issues with shite quality cams....
Trundle
Post by Trundle »
check timing gear and chain also , have you checked to see how much oil pressure it has , ?
slide
Post by slide »
Presuming you got td27? Rocker shafts can wear. Need to remove rocker assembly and check the underside (load side) for wear. (sometimes sliding rockers down shaft is enough to check)
BogBoy
Post by BogBoy »
Yep checked chain and rocker gear already.
If it is the cam shaft can I get it re ground??
philip121
Post by philip121 »
try putting that stuff in that says it will stop ratterling tappets and lifters then youll know if it does but it only lasts a little while
rokhound
Post by rokhound »
BogBoy wrote:Yep checked chain and rocker gear already.
As far as I know (which isn't very), chuck it out and put a new one in (if that is the issue)
BogBoy
Post by BogBoy »
philip121 wrote:try putting that stuff in that says it will stop ratterling tappets and lifters then youll know if it does but it only lasts a little while
I use promar but only in petrol engines.... :?
BogBoy
Post by BogBoy »
Sweet I was just thinking if you got one repaired it shouldn't do it again?.....
