I am going to build a receiver hitch by modifying a standard style towbar.
Plan is to beef up the chassis mounts and weld in a receiver tube. Recess the tube into the existing bar on top of the tounge and add some 5mm bracing. Thanks to Chrome I have a predrilled piece of tube.
Does anyone have the dimensions for how far back the hole should be from the face of the tube? Any other hints or tips welcomed.
Matt
receiver hitch dimensions
Re: receiver hitch dimensions
Drilled mine 50 mm back from the face, had no problem with it
Thanks Coxsy.
Matt.
Matt.
Anyone have a good source for a tow ball receiver? Have seen a few advertised for over $100 which is significantly more than I want to pay.
Matt.
Matt.
Call in at any General Engineering workshop with a box of beer. The length you need is basically scrap to them. They may even weld it up for you on the spot...
Thanks for the reply. I am after the tounge section that slots into the receiver all welded and drilled for the ball and locating pin.
Matt.
Matt.
stinky's old company WTB
True, thanks again Coxsy.
Finished up the towbar today, big improvement over the old bar. Will post up a pic soon.
Matt.
Matt.
