D21 head lights?
For all Nissan related topics
BogBoy
D21 head lights?
Post by BogBoy »
Is it possible to swap the non square d21 headlights to the square d21 ute head lights?
Would i need a ute grill as well?
park lights?
kiwipete
Re: D21 head lights?
Post by kiwipete »
Yes you can but you need the glass headlights, head light buckets and matching grille to go with it all. I do not know about the park lights.
Ph 0212078472
Dirtydog
Post by Dirtydog »
the parklights can be mounted to the guards, but you will need to use tec screws or small bots to mount them, and you will need to trim some parts
They are about 20mm longer that terrano park lights by memory.
(tried that when i couldnt find park lights for my terrano, worked allright but then found cheap terrano lights.
BogBoy
Post by BogBoy »
Wicked.
I saw some crystal style terrano ones on ebay but they are nearly $200 nzd (cut corner type)
But on trademe you can get the 2bx type for $60 a set and they are local
Mahbubu
Newbie
Newbie
Post by Mahbubu »
Dirtydog wrote:the parklights can be mounted to the guards, but you will need to use tec screws or small bots to mount them, and you will need to trim some parts
flashlights.
Is it must to use tec screws or small bots to mount the guards ?
Please make me sure.
Dirtydog
Post by Dirtydog »
yes as the holes are wider apart, its not too major, holds just aswell.
the actual light is longer aswell, compared to the terrano ones.
slide
Post by slide »
BogBoy wrote:Is it possible to swap the non square d21 headlights to the square d21 ute head lights?
I think the early vs late navara are different in headlight setup(and grill/parklights/guards to match)
The late style will swap (d21<->wd21), the early style won't interchange.
Could be proved wrong, this info only based on observations.
Nath
