4AGE swap
For all Daihatsu related topics.
Feroza_dude
Stropper
4AGE swap
Post by Feroza_dude »
Hey guys im new here but im wanting to do a engine swap on my 1990 diahatsu feroza EL currently has a 1.6 carby motor , was wanting to drop a 4age from a corolla/trueno in to it , just wanting to know am i going to need to do alot of modifying on the engine mounts or are they reasonably the same? , thanks
Crash bandicoot
Re: 4AGE swap
Post by Crash bandicoot »
guys in aussie go nuts over these things (rocky) do some googling, one i have seen had a WRX motor in it.
Feroza_dude
Stropper
Re: 4AGE swap
will do thanks, wrx motor would be an interesting combination
Rotazuk
Re: 4AGE swap
Post by Rotazuk »
never worked on a daihatsu but I would expect the engine mounts would be the least of your problems . Expect they will need changing but what are you going to do for gearbox ?
Would another engine from a similar model not be better .
Maybe something like this
http://www.offroadexpress.co.nz/Forums/ ... 48&t=28718
Chris
tuk
Re: 4AGE swap
Post by tuk »
just done a holden v6 conversion on my daihatsu rugger. used holden v6 + auto box and isuzu bighorn transfer case.
New engine and gearbox and transfer case mounts, radiator mounts, front and rear drive shafts.... pretty much had to do everything.
Also will the diff, axels, cv's... handle more power?
tuk
Re: 4AGE swap
Post by tuk »
picture of my hack build
Feroza_dude
Stropper
Re: 4AGE swap
my gear box in it current condition may not handle the extra power from the new engine, the current motor has done 350,000 kms , so by the sounds of it ill need new gearbox,tranfer box and axles as well , the cvs are in quite good condition , well the boots are anyway , not split or damaged , its been a good truck so i want to rebuild it with a new motor, ive seen some one one youtube put a 400 and something cubic inch v8 in a rocky of roughly the same age
Return to “Daihatsu”
