next question,which rating to buy?
14000lb or 20000lb,my truck weighs about 1.8t but as we know with a snatch strap its easy to get 6-8t pull un a stuck vehicle
pintle hook rating,which one
Re: pintle hook rating,which one
Im running a VX weights in at 2.7 tonnes
I have 2 pintals that I use.
The correct claw type which is rated at 22000lbs which has a 6 tonne lifting rate .
The other one I use to tow the trailer with it is rated at 8000 lbs I think. I only tow trailers with this one but I have towed the odd car with it
Pintles have 2 or 3 ratings
Pulling capacity which is rated in the curve of the hook
Load rating which is the weight it supports in the vertical direction
Combinations pintles also have a pulling capacity for top of the ball
Anything over 10,000lbs is widely considered enough for recoveries.
