96 prado tx deisel
Posted: Fri May 31, 2013 7:03 pm
by haz77
Hi,
Im looking at a 96 prado tx 3.0 tdi on sunday and wondered outside of the usual checks when buying a car is there anything to look for, I know about the problems they can have with heads & radiators but is that it?
its on 203'ks, cambelt is done, imported but think the K's since are genuine, the person owning it is unlikely to have been offroad much & its living at a town address.
Is there anything different with the 96 to say the 97,98,99 models other than it not having the extra rear seats?
Mike.
Re: 96 prado tx deisel
Posted: Fri May 31, 2013 7:51 pm
by rokhound
Rear seat are an option (and I may have some for sale real soon :wink: )
They have a weak ctr diff, so don't plan on any proper wheeling adventures in in it, safari type trips won't be a problem however.
I keep hearing about the 1kz head issues, never had one (mine has 280 000 ish kms on it and I got it with 60 000kms 7 years ago), but don't let it get too hot I guess. I have trailered my POS around with mine through some challenging roads (5.5t all up) and while I won't say it was easy, it wasn't too much for it either.
As a preventative thing I would change the front outer ball joints when you get it and through some new bushes in the steering rack. Not a major job, but a major problem when the ball joints let go, (ask me how I know :mrgreen: ).
These are reasonably cheap now and still a good all rounder wagon, just be aware that it is nearly 20 yrs old.
Posted: Fri May 31, 2013 8:08 pm
by haz77
Thanks for that, yours an auto?, heard there ok for towing so long as you dont use O/D but might fit a trans cooler if I get it.
Would be a weekend tow wagon, boat, or horses and this time of year ski feild roads will be on the cards so wont need the ball joints to fail!
I aggree they are a reasonably cheap truck, my budget stops at $15 so unless its a high k late ute there arent many options in the same size / power range.
Will be replacing a faithfull 95 terrano as its not got enough grunt & find the trunk is a bit to small really.
My main concern with these is they have been serviced properly and not had an odo switch, which I doubt this owner would have done.
Posted: Sat Jun 01, 2013 8:25 am
by rokhound
I should have a trans cooler, but just too lazy to put one in it. I didn't bang a service (filter and oil) through the trans until it had done 260 000 kms. It hasn't failed (fingers crossed), but a trans cooler is a good idea with any auto that is hauling weighty trailers.
I was going to get rid of it and buy one of those new double cabs you speak of, but at $60k ech, I would rather get a bigger digger or work truck that will work harder for it's keep at the moment, so I was thinking about chopping mine down to a wellside ute (just because it's different). Idea is 95% approved, the last 5% involves picking up the grinder, and I haven't quite got there yet :lol: .
