hey guys im having trouble fitting new c.v joints to my ln106 hilux, the supplier is saying they should fit as according to his details they should be 90mm, when i measure my old one its 87mm and the one i bought from repco to get me going again was also 87mm,has anyone else had issues fitting cv joints in a hilux he is suggesting previous owner may have replaced my front diff with one from a ln56 or 60.
cheers troy
Hilux cv joints
- hosehustler
Re: Hilux cv joints
He may have given you a prado one they're bigger, if you want to try a std hilux one i've got several, just PM me, im in Kaiapoi
I hate signatures
Re: Hilux cv joints
cheers tim,have since had a few chats with the guy i purchased them of hes been pretty good over the whole thing and its ended up being he sent the wrong ones he is sending me 2 more that will fit.so if anyone wants these mystery c.vs pm me you can have them for free.they are two diffrent brands one has nkn made in japan and the other has wgc rf9517.
measurements
overall diameter 92/94mm
flat spot diameter 89/89.5mm
length of shaft not including bell end 178mm
spline is 27/30
cheers troy
measurements
spline is 27/30
cheers troy
