Vitara Standard Wheel Offset, Best offset for running 31s ?
Posted: Sat Jun 08, 2013 10:03 am
by Chairmen
Could any one help me out, I'm trying to find the standard offset for the Escudo/Vitara ? Searched the net hi an low with mixed results ranging from 0 offset, 25p offset where the main too popping up.
Oh i forgot too mention, preferably would like to know the offset for the escudo/vitara with 16" rim.
As i'm sure there are a lot of you keen suzuki owners out there running 31 x 10.5 on your trucks, Could yous please leave a quick message here an tell me what offset rims you're use an weather you're get much rub would be greatly appreciated...
Re: Vitara Standard Wheel Offset, Best offset for running 31
Posted: Sat Jun 08, 2013 3:41 pm
by Pico42
15 x 8 rims, -19 offset. 31" BFG KM2's. 3" + 3" lift, some guard trimming, no rubbing so far...
No idea what standard was.
Posted: Sat Jun 08, 2013 4:51 pm
by Chairmen
Cheers Pico42
Posted: Sat Jun 08, 2013 5:09 pm
by lneil
15x7 rims (don't feel 8" is necessary for 31s), 31" GT Adventuro muds on about 1inch neg offset, and 31" Super Swampers on 0 offset. Both tire/rim combos give a little rub inside guards on high upward flexing, with footwells beaten back and minor front wheelarch trimming.
Posted: Sat Jun 08, 2013 9:06 pm
by Chairmen
Cheers lneil
Posted: Sun Jun 09, 2013 9:00 am
by loppee
Hi I have o off set rims with little rubbing.My Zuk has a Calmini 3" sup lift and a 2" body lift.
Cheers Woody.
Posted: Sun Jun 09, 2013 11:05 am
by vitz
You up sizing bro?
Body lift time?
Posted: Sun Jun 09, 2013 12:25 pm
by Chairmen
Cheers Woody,
0 offset there are loads of them rims floating around on trade me at the moment. Don't they stick out past the guards some what being a neutral offset ?
Oh an thanks for the winch bumper mate, look 10 times better in person
very happy with it !!
Posted: Sun Jun 09, 2013 12:39 pm
by Chairmen
vitz wrote:You up sizing bro?
Body lift time?
Yeah man, BL in this weekend
Wanting some mud tires an figured if i'm going to fork out for a new set ill go for a full mud tire (MT 117) an not a MT type.
Hopefully with the combination of stuff i'v done so far of lift, inner guard manipulation, an bump stops, now looking for the right offset so fingers crossed too have no or very minimal rubbing.
How your truck going ?
Ill give ya a text when we going up the beach next for a play...
Posted: Mon Jun 10, 2013 7:00 pm
by lneil
Negative offset sticks out further than zero offset. Offset is the measurement of how far away from centre the hub mounting face is. Zero is centre, positive offset is mount towards the outside, neg offset is mount towards the inside, therefore the wheel is positioned further outwards as offset decreases (goes more negative).
Of course 7 inch rims should require 1/2 inch less offset than an 8" rim too.
Posted: Mon Jun 10, 2013 8:08 pm
by loppee
You are welcome.
Woody
Posted: Tue Jun 11, 2013 9:41 am
by churchill
Hey Clay. V6 rims are +25mm offset, GV rims look like they're 0mm offset. Hard to get good info on this.
Posted: Tue Jun 11, 2013 5:52 pm
by Chairmen
Hey Win, Cheers man. It was hard to find good info in the offsets of standard rims. GV 16" rims are +5 offset, so i reckon the 0 offset steel rim on trademe will work ??? Fingers crossed
Posted: Tue Jun 11, 2013 8:10 pm
by churchill
Interesting. I thi k your right, they should be real similar to what you have now. I think gv rims are 6.5" wide so 7" with a 0 offset is close.
