Nissan terrano
Nissan terrano
Hi I have a 2 inch body lift in my terrano and have had to wind the torrision bars up to get it sitting level but now I'm going throught cv boots. Is there anything I can do?
Re: Nissan terrano
You shouldn't of needed to touch the torsion bars unless you have done a suspension lift. Unless the torsion bars had sagged maybe?
Re: Nissan terrano
Yea that's what I thought but it just didn't look right. But I had to wind it up quite a lot which I thought was strange
Re: Nissan terrano
This might be a stupid question, but are all the body lift blocks in place???
Re: Nissan terrano
Yip I've checked and measured them all. They are all there and same size
Re: Nissan terrano
I was thinking maybe change the 4 front blocks for 3 inch blocks and winding the torrision bars back down?
Re: Nissan terrano
fully111 wrote:I was thinking maybe change the 4 front blocks for 3 inch blocks and winding the torrision bars back down?
definitely do not do that!
Re: Nissan terrano
Haha ok then. That's all I could think of
- Shuttle Queen
Re: Nissan terrano
You shouldn't be going through CV boots if its not set too high.
How much of a gap do you have from the top bump-stops?
Do you have a suspension lift (longer springs) in the rear?
Re: Nissan terrano
are cv boots ripping? inner or outters?
plastic or rubber types?
try a different brand off cv boot
or just wind bars down a bit
another d21 terrano
ex lancer build
ex lancer build
Re: Nissan terrano
As far as I know they are standard springs in it. How can I tell? In the rear I have about 65 mm between bump stop and front is 60mm? And rubber cv boots
Re: Nissan terrano
1; What part of the country are you in?
2; can you post up some photos so we can have a better look at what it looks like, of the side profile of the truck and under the front where the bump stops are?
Ph 0212078472
Ph 0212078472
Re: Nissan terrano
Yip will do tomorrow
