Weekend 7/8 October
Posted: Sun Oct 08, 2006 6:27 pm
by Mattman
Replaced the left front shock that crapped out yesterday. Ended up doing upper and lower balljoints as well as when I got under there I could see all the grease squeezing out two splits in the boots.
Also adjusted the wheel bearings and flushed out the brake fluid.
Was hoping to do engine oil and front diff oil but that ill have to wait for next weekend.
Matt.
Posted: Sun Oct 08, 2006 7:34 pm
by billyvanboheman
It's been a busy one at my house as well.
Over the weekend I got these.
Wound up the front torsion bars on the Isuzu.
Moved the power steer reservoir from front to back as per below, L/H pic before, R/H pic after.
This is to make room for the snorkel I'm Building.
On the same goal cut the end off the current air filter case inlet to blank it off, and cut the new hole awaiting the welding in of the new 2 1/2 inch inlet on the other side.
Below photo L/H before, R/H After.
Also fitted one of these for good measure.
Also went to the CHCH swap meet on Saturday.
And watched most of the Great race, which wasn't so good this year with those fix or repair daily’s actually making it to the end for the first time in a long time.
All in all a very good weekend.
Posted: Sun Oct 08, 2006 7:37 pm
by lilpigzuk
Once the hangover subsided on sat morn, went and picked up another possible project, 413 chassis with hilux axles with coil set up. Chassis is fairly well farked, so am not sure yet whether it was a good move or not.
Once the hangover subsided on sun morning :lol: started removing rear axle assembly from last weekends purchase to fit into lil pig. LP had a rooted pinion bearing so rather than swap diffhead I thought may as well the whole assy as my rear axle assembly has hade a pretty hard life. With a few stops (bathurst viewing) got the new diff into LP and was back on the couch with beer watching bathurst by 5 8)
;-p
Posted: Sun Oct 08, 2006 8:10 pm
by wopass
spent all weekend moving my mum into her new pad....
managed to get a little time on the cruiser as well, put some hollow foam round the bits of roll cage that are near the cranium and re attached the seat mounts that had been broken :o now the seats are nice and firm again ! :wink:
Posted: Sun Oct 08, 2006 8:31 pm
by dixie
managed to get a little time on the cruiser as well, put some hollow foam round the bits of roll cage that are near the cranium and re attached the seat mounts that had been broken now the seats are nice and firm again !
AND....we done the mean sketchy repair on your towbar dude!!!HA HA
Posted: Sun Oct 08, 2006 8:34 pm
by hiriklux
fridy night fitted new rear springs :D :D ( bent one thursday night at the bottom of the garden) :( :(
saturday did a bit of gardening and got stuck at the bottom of the garden :oops: :oops: :oops: where winch crapped out :shock: :shock:
so had alook at winch and nearly set the toy on fire managed to rip live off battery :shock: :shock: found out that it was a bit of bakerlite that was buggerd causing the problem so gonna look at fixing it and see if the winch still works
sunday went down mak with rock and h2o and had a play :D :D :D :D
rock pup did all the driving as rocks toy didnt make it off the drive :lol: :lol: :lol: :lol: good effort youngun 8) 8) 8)
Posted: Sun Oct 08, 2006 8:58 pm
by mike
Did an insane amount of work on the LR. Hours and hours of welding :P Think I'm all welded out now. Now I have lots of grinding of crap that I had to cut off to make way for the rear cross member fish plates.
Also pulled the drive flange on the Surf to start removal of broken CV, but the CV was not broken, both spline and flange stripped. The CV spline was only half worn so threw an old flange on and will replace the CV when I get a chance (no hard driving otherwise it will go real easy).
Mike
Posted: Sun Oct 08, 2006 9:11 pm
by Macca
Well after negotiations with petemcc picked up his old engine and chassis with my mates hiab :twisted: . Then proceeded to split it from current box and mate it to box in project truck. Hoping to put up a thread for it when i have time but at the mo all time is going into hack as i want it going labour weekend (slim chance at this rate :cry: )
Posted: Sun Oct 08, 2006 9:16 pm
by MATT4U
Fitted some longer shocks out of a commodore, 25.2inches extended and 14.5 compressed, thats 11.7 inches of travel!!!!!!!!! Just a tad better than the standard 6inches of travel.
then tested them :twisted: :twisted:
Posted: Sun Oct 08, 2006 9:23 pm
by wopass
ohh yea, and dixie did the primo strengthen weld repair on my PHAATSUN ! primo Job to bro :wink:
then i did the primo weld repair on DB's drivers seat :shock: must be eating to many pies :roll: :lol:
Posted: Sun Oct 08, 2006 9:43 pm
by dixie
then i did the primo weld repair on DB's drivers seat must be eating to many pies
Anytime bro,but the primo job would have been me cutting that bar off and starting again.RRRRGH,RRRRGH......bloody half pie sketchy jobs.HaHa!!
Posted: Sun Oct 08, 2006 9:45 pm
by mike
MATT4U wrote:Fitted some longer shocks out of a commodore, 25.2inches extended and 14.5 compressed, thats 11.7 inches of travel!!!!!!!!! Just a tad better than the standard 6inches of travel.
So they are good then? turoa was right?? I wonder if they would fit a LR :?:
Mike
Posted: Sun Oct 08, 2006 9:49 pm
by MATT4U
Mike
For $20 and this Image
to Image
Great
Posted: Sun Oct 08, 2006 9:51 pm
by billyvanboheman
Mike
I used to sell Gabrial shocks in a previous job, catalouges had some great charts with mountings and extended and compressed lengths, I think most manufacturers do the same, I use Autolign for shocks and they use the same method.
Posted: Sun Oct 08, 2006 10:19 pm
by DieselBoy
And it was PRIMO!!!!!
The trucks still suffering the effects of being draged through the wires loop over 6mnths later :lol: , well, that and two many pies :wink:
Posted: Mon Oct 09, 2006 7:16 pm
by 4wdnuts
well this weekend i got sick of ripping my stereo aerial off ( i always forget to push it down :oops: ) when driving under trees or scrub. so i got an electric one out of a nissan pulsar and wired it up to a switch on the dash so i can lower it whenever it looks like its going to get a hiding.
also put in an inverter to charge up camera and radio batteries when out on the trails. just need to do the dual battery system now.
Posted: Tue Oct 10, 2006 10:07 am
by Moriarty
Thought about an inverter, decided that the battery charger (AA nicads for Canon Cam) came with its own 12V charger and the radios the same.
Siwsan's Fridge is 12V and the camp light is a fancy Dan multi LED one. so I guess I saved a min of $150
