whats the best petrol tank bush fix
Dannz71
Post by Dannz71 »
Recently a mate of mine came down quite hard on a stump in the bush and cracked a weld in his fuel tank and it started to leak, a slow drip I might add however we were planning to be out there for a few days so we didn't want to waste any fuel even though it was a slow leak. So we sorta jerryed it up with a bita tape and some form of silicone shit he had rolling around in the back. Now were normally pretty prepared for most issues in the spares department with hoses and belts tools and bolts etc however we we realized that we weren't prepared for a fuel tank leak and as fuel is pretty vital to a 4x4 I wanted your guys input on the best way to fix a fuel tank in the bush when ya miles from the nearest welder or replacement. What sticks to aluminum or steel the best and doesn't break down under fuel ... temporarily anyway...
lilpigzuk
Tiger Balm
Re: whats the best petrol tank bush fix
Post by lilpigzuk »
Bar of Soap. Seen in used, was funny as fark considering the vehicle it was and location of tank :mrgreen:
Jafa
Post by Jafa »
Kneadit
works great
021 273 9942
jafa@inspire.net.nz
Dirtydog
Post by Dirtydog »
Any type of fast setting epoxy would be good, if you get a small peice of fiberglass matt and apply it with the epoxy it would be even stronger.
Petemcc
Post by Petemcc »
lilpigzuk wrote:Bar of Soap. Seen in used, was funny as fark considering the vehicle it was and location of tank :mrgreen:
I tried this the other day with no luck. had a pin hole on the bottom of the tank and rubbed the bar around for a while trying to get some in the hole but it didn't work at all.
Maybe worth carrying one of these kits?
http://www.supercheapauto.co.nz/online- ... 9950#Cross
albundy
Rolly Polly
Post by albundy »
Knead it. Fixes anything and you can make anything out of it. Made a set of cone washers for a asin hub when we had to fix a blown hub and cv on my mates 80 last weekend. We didn't have any. Worked a treat.
sig
Jeep Jeep
Post by sig »
knead it 8)
chrome
Post by chrome »
sunlight soap,
easier to clean out for repair job
DIRTY OLD HILUX
022 519 7700
Dannz71
Post by Dannz71 »
chrome wrote:sunlight soap,
How dus soap work du ya hafta melt it on or something?
Dannz71
Post by Dannz71 »
Jafa wrote:Kneadit
works great
Does it still work at the the bottom of the tank like will it dry with the fuel dripping?
sibainmud
Post by sibainmud »
Dannz71 wrote:
Jafa wrote:Kneadit
works great
Sure will. 2 pack epoxy putty. Once mixed together well, nothing stops it curing. It takes a bit longer in colder climbs. Years ago i used it to fix a corrosion hole in the float bowl of a Honda Civic. It was still holding when I sold it some years later :lol:
chrome
Post by chrome »
just rub it hard into the hole, basically ya force the shit in till the gas stops leaking
DIRTY OLD HILUX
022 519 7700
Fakey
Post by Fakey »
Ive used soap on cracked alloy diesel tanks on trucks, I thought my boss was pulling my leg when he first told me to do it but it works well. Not permanent tho.
Didn't barbie drive a jeep??
Return to “Tool Shed”
