td27eti mechanical pump conversion which injectors do i use
thestig
Post by thestig »
td27eti mechanical pump conversion which injectors do i use td27 or td27eti?
sibainmud
Re: td27eti mechanical pump conversion which injectors do i
Post by sibainmud »
Answer is fairly obvious, if the pump goes with the same timing gear then it would make sense to keep the "matched" injectors with the same pump.
http://www.offroadexpress.co.nz/Forums/viewtopic.php?f=6&t=36214
Pays to just bump your first thread, than start a new one :wink:
Answers may not be instantaneous, but they do come :)
If it was me, I would exchange the injectors for reconditioned ones, then you know they are mint.
thestig
Post by thestig »
thanks
Return to “Tool Shed”
