planning my td42 turbo set up
y60 safari driver
Post by y60 safari driver »
looking for a good turbo charger for my na td42
anybody have any ideas, I am on a budget so not looking at top of the line turbos but don't want to buy crap
are these any good?
http://www.trademe.co.nz/motors/car-par ... 884081.htm
also i'm new to external waste gates so any advice on what to look for would be great
thanks people
keithal
Re: planning my td42 turbo set up
Post by keithal »
have a search of the forum there have been plenty of threads about this
imo that turbo is wayy to big for a td42
rule of thumb for a diesel is use a turbo off a car with half the capacity ie a 2litre car
y60 safari driver
thanks I was thinking it would be to big
I also have a turbo off a 4jx1 that has hardly had any use was wondering if I could use that
crazyclark31
Post by crazyclark31 »
Have done a couple of turbo steps on safaris now and after a couple lessons :oops: have found tdo5s a really good unit. Have used the ones off a wrx with the 16g small wheel compressor. Boosts up nice and quick and holds smooth right to redline.
Most important that you put rebuild kit in if you get a second hand unit.
Not sure what kinda budget you have but if you doing it yourself then if you can making a good flowing j-pipe will work really well and save some coin as well.
Ideally you want something with an internal wastegate. Less plumbing and hoses to leak.
Trundle
Post by Trundle »
Depending on you budget i stock a setup using holset hx35 motorsport turbo using steam pipe manifolds with merge collectors ,
y60 safari driver
cool thanks guys
I plan on having a go at making up my own manifold to start with
PigFmr
Post by PigFmr »
custom manifold is the way to go,i have a extractor (flows) setup ,wiv a top mount CT26 turbo wiv a greddy intercooler top mount,runs great and has done for neally 4years now
has a 3 inch exhaust from the turbo and internal waste gate pipe is 3inch aswell and its all straight thru
my GQ ute will be forsale soon on trd me u will able to see pics then
vince
tweake
Post by tweake »
first thing is which td42 you have. one has weaker pistons etc and not suitable for high power.
the next is what power are you chasing and can you afford IP to be modded.
if budget is limited it usually means sticking with stock pump which will limit what you can do. no point with big turbo if you can't pour in the fuel.
i would steer clear of any tuned collector style manifolds. they don't work well with limited fuelling. far better to make a log style and keep the runners as short as possible.
theres tons of info on patrol4x4 which will keep you busy for a few months !
y60 safari driver
it is a 89 silver top
i'm not looking to build a comp truck just want to get up hills a bit quicker
how many psi can these handle (looking at fitting a td05 16g) and what point do I need to mod the pump? I have to get it rebuilt anyway so if i'll need to do it i'll do it then
cheers for the help guys
y60 safari driver
also what do you do to the pump? had a quick search but couldn't find anything definate
tweake
Post by tweake »
http://www.patrol4x4.com/forum/engine-d ... d42-80484/
good starting point if you havn't read it yet.
not sure a what point you would need to mod the pump. i understand there is a couple of differences over the years.
just ask on patrol forum.
tweake
Post by tweake »
y60 safari driver wrote:also what do you do to the pump? had a quick search but couldn't find anything definate
i don't think any injection guy is going to let loose his trade secrets. :wink:
DaveM
Post by DaveM »
Pump will depend on setup. Anything from winding up fuel a little, to adding boost compensator from a TD27t pump, or a plunger from a Landcruiser
crazyclark31
If your running a small wheel 16g then you won't need to mod your pump unless you want to run massive boost.
As for set up a good log style manifold and a good intercooler with a 3in exhaust will give you all the power you'll need.esp at low to mid teens boost.
Make sure you put a decent size oil return pipe to the sump as too small one will cause issues
