tire size discrepancy's
poss682
Post by poss682 »
i know there are discrepancy's between tire size and actual size between brands in height but is there the same discrepancy with the width??
mudlva
Re: tire size discrepancy's
Post by mudlva »
Ive found that the tyre width size has no relevacne to tread width, more to say how wide the tyre will be, when measuring the overall on the side wall. Some tyres have a very narrow tread width in relation to what the tyre manufacture say the width will be
Know what i mean
poss682
Post by poss682 »
yea i get you my girlfriends 33's Goodyear wranglers tread is norrower than my kl71 32's
keithal
Post by keithal »
poss682 wrote:yea i get you my girlfriends 33's Goodyear wranglers tread is norrower than my kl71 32's
you know 33" and 32" is the diameter not the width right?
zukmeista
Post by zukmeista »
Yes but 32's are usually 11.5" wide and 33's are usually 12.5" wide so I assume that's what he means.
poss682
Post by poss682 »
yea...
32" kl71's come in 11.5" and 33" wrangler's come in 12.5" but the 32's tread is wider than the 33's
callum007
Post by callum007 »
Sue the tyre companies...
Read the manufacturers specs to see at what pressure their measurements are based on.
Are you comparing apples and apples? my 35's at 3 psi at 32" tall and are 1.5" narrower than when they inflated, but this all changes when they off the vehicle.. If you get my drift
poss682
Post by poss682 »
its just im after a reasonably priced narrow 33 thought some one might shed some light on this
BlakeNZ
Post by BlakeNZ »
do you have 15" rims or 16"?
poss682
Post by poss682 »
15 s
Return to “Tyres”
