BJ74 - Rebuild or new motor?
Posted: Thu Jun 20, 2013 11:22 am
by joeninetynz
It's been a mare of a week.
I've cooked the 13BT and she needs a rebuild.
Should I rebuild her or look for a upgrade. Contemplating a 1HZ (if I can find one- help if you can).
What other options should I consider in diesel?
Re: BJ74 - Rebuild or new motor?
Posted: Thu Jun 20, 2013 12:14 pm
by ChurchurDan
1kz?
Posted: Thu Jun 20, 2013 6:42 pm
by 109
joeninetynz wrote:It's been a mare of a week.
My .002c
Go another 13BT ( or go for a rebuild) The 1HZ's have abit more torque ( 1HZs 285nm vs 13BT 217nm) but only 9more hp at factory. You could prob get that out of a 13BT with abit of tuning
Don't get me wrong , 1HZ's are awesome engines , I use to run one in my70 but the hassle of new engine mounts , you'd also have to find a HZ gearbox or swap the output shaft because the 4 cyl and 6 cly shafts are different. Swapping the shafts means taking the gearbox to bits . Different bellhousing , cert etc
For the gains its alot of work . If you were gonna put that effort in a 1HDT might be more worthwhile
Just things to consider
Posted: Thu Jun 20, 2013 9:57 pm
by Fakey
v8
or rebuild what you gotv8 or rebuild what you got
Posted: Fri Jun 21, 2013 12:38 pm
by joeninetynz
Thanks 109. I'm in the proces of shopping around for the rebuild. If it's too deal, I'm writing it off.
