HI All
Im after a full chassis for a GU LWB 98 safari,any idea where I can find one,also a pair of rear rotors,Thanks
Safari GU chassis wanted
Re: Safari GU chassis wanted
Australia would be your best bet
What do you want it for? Dont think thered be too many getting wrecked in NZ that are in good condition
Didn't barbie drive a jeep??
I've got a pair of rear rotors from a GU . They Are used discs ,
(Also have the Rear Diff housing, side axels (no diff head), and brake callipers if anyone interested)
If you can pick them up that be good, I'm in Auckland
Flick me a PM if you want them.
maybe he bought a cheap gu with a buggered chassis off trade me, are GQ lwb chassis very similar??
Fakey wrote:Australia would be your best betWhat do you want it for? Dont think thered be too many getting wrecked in NZ that are in good condition
Complete dereg 4.2 GU sold on TM for $5k. Little untidy, but otherwise fine. If this had been posted a day earlier, I would have hit the buy now!
yip I bought it,chassis is a bit rusty in rear it was used to launch boat,could get it fixed but already talked to ltsa about re vin as it was dereg, they sent me to certifier panel beater who would assess it for 200 then work required and other assessments it was running up to 1k very fast so best start with a good one if I can find one see what happens cheers.
i did hover over the buy now as soon as it was listed but to much other stuff, there is a long wheel base gq chassis on trademe but i dont know how close they are?
I know a Gu ute cab bolts straight onto a LWB GQ chassis so I cant see it being too much drama to make the wagon cab fit
Hi all Iown a 92 lwb petrol safari and had the GU and the GQ up on the hoist beside each other and they are pretty much identical with a few differences like the rear sway bar mounts up slightly different and rear body to chassis mount is slightly bigger on the GU but still in the same place, so I guess im after a GU or GQ chassis if any one has one lying around let me know,I live in Whangamata and am in 4x4 club here cheers Ron.
http://www.trademe.co.nz/motors/car-par ... 764705.htm
2 mins on trade me and here you go.. in aucks aswell.
