FS Landcruiser 8" Lockright front and LSD rear
Still Unbroken
Post by Still Unbroken »
juz
Re: FS Landcruiser 8" Lockright front and LSD rear
Post by juz »
What do they drive like with lockrite in the front onroad, say in hi 4wd eg gravel or snow
Cheers justin
Smurf
Post by Smurf »
what is the model number for the lock-right
Still Unbroken
It drives ok but can be quite heavy in the steering when it finds grip... I've used it extensively at local club champs and numerous trips to the coast. As I said, steering is the only real issue but can be overcome by getting off the gas (it then releases) when you need to turn sharp.
The model is a 1610 LR from memory
