First time 4wd diesel owner today 1992 safari lwb td42
Posted: Thu Jun 27, 2013 6:13 pm
by Kelvtd42
Hi I'm a new owner. Just brought a 1992 nissan safari manual y60 td42
Brought for $4000 some issues need looking at first
Rust on sunroof
Brownish radiator fluid
Handles like a boat
Low speed shake
Speedo sit on 180 and moves up and down when running
Central locking not working
Going to turn this info a offload sleeper so need to make it reliable
Any suggestions and support are welcome. In term of my own knowledge, it is very basic this is my first diesel and 4wd
Thanks guys
Re: First time 4wd diesel owner today 1992 safari lwb td42
Posted: Thu Jun 27, 2013 7:39 pm
by crazyclark31
those issues are std safari ones.
Flush the radiator and new antifreaze. Also would to pay to check the water pump.
Boat handling easy fix. Springs and shocks are easy to sort. Pay not to go above 2-3 inch lift or it affects the handling to much without big $$$$ being spent.
Wheel shake will be worn bushes . But would check wheel balance first then its just process off elimination.
Speedo will need sparky attention. Normally needs the solder on back of dash cluster resoldered
Mike
Posted: Thu Jun 27, 2013 7:42 pm
by Trundle
If you do the pump and coolant , bang a new genuine nissan thermostat in it (there only 30 buks ) also doesnt hurt to get a tank taken of the radiator and flushed (100 buks ) and renew the viscous fan oil
Posted: Thu Jun 27, 2013 8:43 pm
by Kelvtd42
Hey thanks for your reply guys.
So the sunroof has been quoted at around $1000 for new sheet metal work rust cut out and painted over.
Also as I have no tools or knowledge to do the service and one you can recommend in Auckland to just give the car a service and general look over. Really want to just freshen the car up and make it last another 20 years.
Any recommendation in a sparky with the knowledge to do this ?
I'm in Akl
Many thanks
Posted: Thu Jun 27, 2013 8:58 pm
by coxsy
Wiri auto electricail for the wiring , service the closest garage to your work ten plus litres of engine oil plus filters costs
Posted: Thu Jun 27, 2013 9:09 pm
by Ralfie
Kelvtd42 wrote:Hey thanks for your reply guys.
I'm in Akl
Many thanks
Depends on which part of Auckland you are. North, South, East or West?
Can recommend several places but don't want you running all the way south when you are up Rodney way.
Posted: Thu Jun 27, 2013 9:58 pm
by Kelvtd42
I'm in central Auckland so I guess I can go either way
:D
Posted: Thu Jun 27, 2013 10:51 pm
by Ralfie
Then Central Motors in Pollen Street Grey Lynn is a good place to start. Garry is the guys name. A Jeep man and 4wd'er so handy to know.
He can also give you assistance with price on the rust repairs.
Its hard to know if the quoted price is reasonable until you have seen what the extent of the rust is.
I know of a Jeep roof that had rust repairs done and that cost $2.5k so $1,000 doesn't sound too bad if it includes paint.
Posted: Fri Jun 28, 2013 5:09 pm
by Kelvtd42
Thanks guys
