29th - 30th
catalystracing
29th - 30th
Post by catalystracing »
Ill get this one underway..
Removed the front seats out of the Lux and tightened up the loose bolts that were letting the backs move around and repaired the seat position slide mechanism, removed rear door cards and got the central locking freed up. Must be worth heaps more now :D
meatc
Re: 29th - 30th
Post by meatc »
Having not really done anything on my own Zuk for a while I spent the avo finishing stripping the chassis off. Old one is now out side and new LWB chassis is now in the shed, upside down :roll: but in the shed.
More work on Darinz new Nissan tomorrow, Taupo 1000 is coming fast.
Oh get my new dimple dies tomorrow, think the mate that made them has a few extra sets to, if anyone wants some.
kbushnz
Re: 29th - 30th
Post by kbushnz »
Removed the electric winch and support plate off the playdoh... Raised the front 10mm.. whoot whoot... :lol: And back down to one battery.. Pinched one to put in the little 121 as its blew all its acid out....The 121 starts really fast now !
tweake
Re: 29th - 30th
Post by tweake »
pulled gearbox out. getting ready to rebuild it and fix up the mistake i made with the clutch last time.
Dirtydog
Re: 29th - 30th
Post by Dirtydog »
Went to start the terrano to do some firewood, wouldnt start.
Quick though was to bang starter, which was the problem.
Major problem is that i had to do that every time i turned the key....
Also got to drive a david brown 950, about a 50's tractor to move a log, so much fun starting up a old tractor thats been sitting for a few years. went well after it started, apart from the sparks out the exhaust......
muddyplumber
Spring Free
Re: 29th - 30th
Post by muddyplumber »
Got a pair of 80 series locked diffs that will find there way under the Mitzi :mrgreen:
Hug-o
Re: 29th - 30th
Post by Hug-o »
Installed a 20inch LED bar
Its really bright!
Drove to Taranaki from Auckland to drop a container off..
http://i1195.photobucket.com/albums/aa3 ... F8F3CF.jpg
Its was cold
Bought another dog
Sunday is install 50mm lift and pull motor from race car... Fun fun...
Hugo -02102470477
yael
Re: 29th - 30th
Post by yael »
What sort of $ would he be looking at for them??
If you cant beat us Gingers, JOIN US!!
tow99
Re: 29th - 30th
Post by tow99 »
semi 4x4 related.
recycled some landcruiser parts to make a hose reel for outside my shed.used a bj40 swinging spare wheel carrier and a damaged 16inch rim i was going to scrap.now i won't trip over the bloody thing!
onebadman
Re: 29th - 30th
Post by onebadman »
went for another play in waimake and spent a bita time trckking around godly head
lincooln
Re: 29th - 30th
Post by lincooln »
went for a trip on my dads place in Kaiwaka, was good times
Lubrication Specialist
Lubrication Engineers
Crash bandicoot
Re: 29th - 30th
Post by Crash bandicoot »
Installed the dual battery system in the mistral, hard wired the A/C pump to a dash switch and plumbed up to the engine breather for oily air and converted fire extinguisher for a reservoir
jonossiksilvia
Re: 29th - 30th
Post by jonossiksilvia »
Went for a easy play at the waimak today with a mate. First hole ended up with both of us winching out. No action shots as to busy driving. Heres a pic
Suza
Re: 29th - 30th
Post by Suza »
Used the Safari to clear to 4x4 utes from a MVC I attended this morning on a one way bridge, bit of dragging, bit of winching and then a bit of big ditch verge 4x4 action :lol:
ladeda
Re: 29th - 30th
Post by ladeda »
Finally got the shita out of the shed. Took it to work with the aim of changing ova the steering box and a whole list of other things. Then got called out to a Scania set up for water cutting that had flat bats on its pump motor, that wasted about two hours. Spent the rest of the day wrestling the steering box out of the lada. Really hope I Neva have to do that in the bush...ever... :evil: :roll: .I did read somewhere on here it was a mission, can safely say now I believe it. :lol:
trucked
Re: 29th - 30th
Post by trucked »
Nearly finished the new bar for the hilux, has decent enough approach angle and winch is nice and high out of the crap.
Colinl
Re: 29th - 30th
Post by Colinl »
Went and shot some fuggin ducks up Waiarapa for last day of season. Pheasants, quails & canada geese now on to be shot and eaten list.
TJ
Re: 29th - 30th
Post by TJ »
Colinl wrote:Went and shot some fuggin ducks up Waiarapa for last day of season. Pheasants, quails & canada geese now on to be shot and eaten list.
Did that involve four wheeling? Otherwise its off topic here.
Dirtydog
Re: 29th - 30th
Post by Dirtydog »
Picked up a 20L of 15-40 for the terrano/bighorn for $104 from repco,
Seems like a good buy considering a 10L is usually about $95.
Also got some brake fluid and some rain-ex anti fog aswell, works bloody wonders.
Also fixed aircon unit, blown fuse aswell as another which i still cant figure out what it was too. (the glory of owning a jap import)
jimichelle
Re: 29th - 30th
Post by jimichelle »
how does the break fluid work?
you apply liberally until it breaks? or just smear it on? :wink:
Re: 29th - 30th
saw red mu tonight 33'' or 35 maxiss mudzillas no lift fa guard cleance :D :D
fash
Re: 29th - 30th
Post by fash »
jimichelle wrote:how does the break fluid work?
:lol: :lol: :lol: :lol:
Dirtydog
Re: 29th - 30th
Post by Dirtydog »
It was early and i hadnt had my cup of coffee yet lol
Flannel
Re: 29th - 30th
Post by Flannel »
Replaced the Swaybar link and D bushes with OEM rubber ones (corners a fair bit better now). Cleaned up the links and changed the engine oil while I was at it.
Ordered a 3" Exhaust and the last few bits for my Front Axle rebuild including the later 80 series CV's and flanges.
Tested out the rear cargo Mudgrabba mat by taking the dogs out in it, carpet stayed clean but everything else still filthy.
Hug-o
Re: 29th - 30th
Post by Hug-o »
50mm lift all round now. Front ended up been like 70-80mm haha now i just need some 35"s
Hugo -02102470477
sibainmud
Re: 29th - 30th
Post by sibainmud »
Friday night, replaced broken spring,
Drove up the back of possum palace, forgot diff lock, switched it on and speared off the track to rest drivers door on a tree :oops: :oops: Now it matchs the passengers one :P Going for the "hourglass" look :lol: :lol:
All going well until Sunday lunch time, when on a steep climb got a little air time with turbo fully spooled, and broke the shaft when it came down :roll:
Anyone know of any standard TD27 turbos, going cheap? That was my last one :( Need to find one in next week or so.
datsunsafari
Re: 29th - 30th
Post by datsunsafari »
farkinhell simon might have to ditch the terrano and get yourself a bulldozer or a tank.............or a safari :wink: any pics of the latest panel damage.i don't know who's winning the "wreck my truck"compition you or caleb?seems to be too close to call :lol:
