The Lada is up for sale
Lada Build Thread
Some of you might have noticed my comment on one of my build threads about a bad back, it is bad enough I'm looking at surgery... so I'm winding up my company that means the lada is for sale
Whats the call do I strip it and sell off the parts or is there anyone interested in it finished
I don't mind finishing it, I'd like to see it out there doing its thing (state I'm in would take me 2 months)
If some one is keen I'll sell it for $0 labour yep all you'll be paying for is the materials that have gone in.....
$8580.00
Tyres - New 33" x 10.5" x 15" GT Savero's
Rims - Heavy wall ROH (old school & stronger) rims converted to external beadlocks, and hot galv dipped with 36 bolt rings and rated stainless cap screws
Rear Axle - Coil sprung rear surf axle striped and lada suspension fitted
Diff - 4.3 four spider open
Brakes - New vented IFS disks that have been machined and drilled (2.5kgs lighter than standard)
Calipers - V6 surf Calipers that have been narrowed to work with the above disks (over all gives the equivelent of 10 more hp at wheels), new pistons, seal kits and pads
25mm steel spacers
Rear Shocks - Standard used ones at the moment
Front Axle - Hilux solid axle fitted for coilover 3 link, New swivil housing kit, Clearanced to fit 75 series CV's, fitted with new 75 series CV's
Diff - 4.3 High pinion
Brakes New vented 40 series disks that have been machined and drilled etc
Calipers -V6 surf calipers, narrowed to fit with new pistons seals and pads
IFS hub swop with ali wheel spacers
Steering
Steering arms - Custom made "I" beam arms with 4130 seats for 80 series ball joints
Pitman arm - Custom made "I" beam etc
Tie Rod - Custom made Carbon hollow HD with new 80 series ball joints
Drag Link - Custom made carbon etc
Steering Box - Suzuki grand vitara
Steering Wheel - After market bling thing
Steering pump - Nissan Serrena
Motor - SR20DE, from a Nissan Serrena van 86,000 km's, cooling is from New alloy radiators either side up under bonnet with audi A4 cooling fans
Trans - Nissan U13 bluebird front wheel drive, center diff welded and stub axle conversion to run hilux drive flanges with bearing mounts
Suspension
Rear - standard lada coils
Front - New Rancho RS9000 12" travel shocks on custom Coilover conversion, New Heim joints through out
Cab
Seats - New Racepro seats (will never deal with these guys again, took over 6 months for them to supply these ) been modified with closed cell foam padding
Belts - 6 point harness's
Dash - New aftermarket, oil pressure, water temp & voltage
Body - lol well look for yourself cut clearanced fuckedwith and rebuilt, 6 point cage with multiple contact pads, space framed transmission tunnel and front engine bay with Unibody work on front guards
Complete weight estimated at 900-950kgs
Contact Reece
PM me here or 027 541 8794
The Lada is up for sale....
Re: The Lada is up for sale....
Forgot to add fiddle brakes on the rear axle using a pair of new hilman Imp master cylinders
and a heap of spare motor bits
Nissan Safari with Pink bits
Now theres a challenge for you Bub's, If anyone can tame a beast I recon it would be you.
GO GIRL,
FITZY.
GO GIRL,
FITZY.
i have seen it and it will be a awesome truck ... what about you ???
