Hey folks,
ive read in snippets all over ore and the web amount running a wire and some relays etc for nissan gearboxs, and the end result is you are able to select the gear you want, and it stays in that gear untill you move selector or flick the switch. To select gear, you go 1st, 2nd, d with overdrive off is third, then overdrive on is 4th.
Only problem is i cant find where there is a complete how to or guide, and all of them seem different.
I also want to do the TC lock up mod at he same time (since im mucking around with wires anyway)
Cheers in advance folks, and yes ive used the search function, only came up with snippets here and there.
Auto Select mod
Re: Auto Select mod
right well thats the TC lock up dont know how i missed that in the search, must be the keywords that i used..
Now, with the selector, there was a kit i saw that came with a little shifter on its own, anyone know which one im talking about?
fullthrottle
- Shuttle Queen
Re: Auto Select mod
Yep, here it is:
http://www.radesignsproducts.com/Rail.html
In original post:
http://www.offroadexpress.co.nz/Forums/ ... &start=225
Looks good. You could probably make any type of shifter.
http://www.radesignsproducts.com/Customer_Installed.php
In original post:
