more advise required! I have been told that a 2lt turbo gearbox<w56> will fit the 1kzte.Wot is the right bell housing for this to work?Does it have a identity number or some means of identifying it?Wot vechiles does it come in?Cheers for help.
R151F is the one in the manual. Have a look at gregorys manual no 521, its the KZN hi-luxs that might have more info. I have the gregorys 1KZ manual here and the an electronic version of the Toyota 1KZ workshop manual.
PM me your email address and I'll send the workshop manual. Has fault codes and everything in it.
One thing to bear in mind though is there are two versions of sensors and ECU. V1 ECU will not work with V2 sensors and vice versa.
Who knew Prados could fly?
