SWB 3.5V6 Manual drivetrain to LWB 2.5 Manual
Posted: Fri Jul 05, 2013 4:30 pm
I currently own a LWB 2.5TD GLS NH Pajero with a Manual transmission and the Super-Select transfer case. I am looking to swap in a 4D56T from a newer Triton and upgrading the drivetrain to cope with the torque. I am looking at a 3.5 V6 Manual as I have heard these are the strongest of the Gen 2s, and I have a few questions.
1 - What components will need swapping? (Obviously the Diffs, but is the entire axle required? etc. )
2 - Will a 3.5V6 SWB drivetrain be fine provided a LWB driveshaft is used?
3 - What are the differences between the GDI and Non-GDI transmissions?
4 - Will the majority of IFS components remain the same bar diffs and axles?
5 - I know the 2.8TD has a factory body lift to clear the transmission, is this the same with the 3.5?
6 - Any recommendations on how to make the swap as simple as possible?
Cheers, Karl
Cheers, Karl
