4-6 July
yael
4-6 July
Post by yael »
Looks like I get to start this one off...
Decided a couple of weeks back the poor old GQ wasn't going to pass a WOF on rust and tyres so today I've cut the rust out from around the windscreen and 3 other spots on the roof welded patches in and rust killed them, Just need trusty ole bog now to make them look pretty..
Also got enthusatic and did a rear quarter chop so now I have to figure out how I'm going to finish it off to make it look good now haha :roll:
Also has any one got any good pics & ideas on how is best to do a front guard chop to fit 315-75-R16 ??
If you cant beat us Gingers, JOIN US!!
datsunsafari
Re: 4-6 July
Post by datsunsafari »
^^ front guards are a piece of piss to chop compared to the rear guards as the rear are double skin and the front are single skin,just mark out where you want to cut(masking tape works well)attack with angle grinder with a 1mm cutting disk,i used a cresent to fold a new lip along with a little hammer and dolly action.dont forget to paint any bare steel or mr rust will be paying you a visit :) you can also use radius arm spacers to push the diff forward a bit,it helps with front tyre rubbing on the rear of the front guard.
Dirtydog
Re: 4-6 July
Post by Dirtydog »
Still waiting for parts to arrive for the terrano, then i can get stuck in.
Cleaned up garage again, sorted tools and what not out so i know where everything is, also started mucking around with the go kart.
Mounted engine to a plate so it can be mounted to frame, and started sorting pulley's out, what a pain when ya dont have anything to base them off, considering front mounting the engine.......
basics
Re: 4-6 July
Post by basics »
took about a liter of water out of each headlight and re sealed the unit.
and munching down american hot dogs waiting to go to lone star to meet the welly crew :lol:
99 pajero exceed 3.2
fullthrottle
Shuttle Queen
Re: 4-6 July
Post by fullthrottle »
Picked up a new truck today. Took it for a test run, but the dam thing keeps getting stuck in the hole. Having to use the winch yet again....
tweake
Re: 4-6 July
Post by tweake »
gearbox is 90% done.
made a few stuff ups and got well used to pulling gears/bearings off. just have to make up some decent breathers for it.
the shifter bushes where completely stuffed. some heavy duty marlin ones going in.
Bubba
Re: 4-6 July
Post by Bubba »
Went to buy new wipers for the jeep but it was raining so didn't, I also went to fix the heater but it was too cold... Ironic really
Benjamin Franklin
yeti
Bruiser
Re: 4-6 July
Post by yeti »
Bubba wrote:Went to buy new wipers for the jeep but it was raining so didn't, I also went to fix the heater but it was too cold... Ironic really
here bubba hope this write up helps re blade thingy's
http://www.offroadexpress.co.nz/Forums/ ... =4&t=35171
v8 tj...luvs the gas......
onebadman
Re: 4-6 July
Post by onebadman »
found worsleys on one of my tiki tours got stuck spent 30min diggin myself out need a winch lol
Cameron
Re: 4-6 July
Post by Cameron »
went for a cruise, about 20km return up the river in my landrover.
good fun.
'ol 202 didn't even complain at sucking a guts full of water through the air cleaner after one crossing was about headlamp height. :lol:
also took me 'til today to realise how on the piss one of the guards is. damn
dean zuk
Re: 4-6 July
Post by dean zuk »
Made up a full 2inch exhaust including headers for the sj, sounds much better now :mrgreen:
wopass
Re: 4-6 July
Post by wopass »
Walked past a fawdy that sits in my garage on satday, changed out a sticky starter motor in my VX Sunday. Mint weekend of wheelin!...
KIWI_TERRANO
Re: 4-6 July
Post by KIWI_TERRANO »
Had a attack at selwyn river in canterbury, 3 boats a little bit of pushing and then a really high and dry when a mate found a bank to park on... Was good fun got from dunsandle up to the bearly road bridge, got a weird look from a cop while have lunch :lol:
Coljag
Re: 4-6 July
Post by Coljag »
Cleaned my Jeep! Inside and out, took all frigin day! Then changed my front right suspension ball joints, took 4 hours! Have learned and hopefully the left side will be easier. Thank godness for the correct tools! She looks real flash now though!
tweake
Re: 4-6 July
Post by tweake »
pulled out toyota stupid little gearbox breathers, tapped the case and fitted some air fittings. got the last of the shifter bushes in. fitted the shifter and found the gearbox was locked in reverse.
pulled the cases off, put it into neutral, all back together and all ok.
juz
Re: 4-6 July
Post by juz »
Bought a Hilux, now to tidy n sell the cruiser. :mrgreen:
hamboy
Re: 4-6 July
Post by hamboy »
Went for a nose down the river....Got a bit carried away :roll: :lol:
T-Boon
Re: 4-6 July
Post by T-Boon »
Finally the truck is going again with no serious issues! V8 feels so good!
To Boon or not to Boon.
Flannel
Re: 4-6 July
Post by Flannel »
Changed the last of the swaybar bushes i was waiting on.
Took the new 3" zorst for a tour around the town.
tweake
Re: 4-6 July
Post by tweake »
fix up the clutch today. replaced the spigot bearing, first time using the grease method which worked perfectly but a messy clean up.
packed out the pivot point so hopefully now the clutch engagement point won't be buried in carpet !
hope to have the gearbox back in tomorrow.
