4jb1-t Oil/Coolant Heat exchanger - 36mm socket?
Posted: Wed Jul 10, 2013 12:51 pm
by buried
Hey,
When redoing the hoses from the heat exchanger I removed the oil filter and the heat exchanger itself was loose, there is a recessed 36mm nut that locks it down. I've tried three 36mm sockets, all impact but the walls are too thick to get into the recess. Anyone know where i can buy 36mm 12 slot (jaggered edge) socket? Repco, supercheap, bnt dont seem to have them :/ Alternativly, does anyone in Auckland have one I can borrow/return for a small fee?
Thanks
Josh
Re: 4jb1-t Oil/Coolant Heat exchanger - 36mm socket?
Posted: Wed Jul 10, 2013 1:18 pm
by kbushnz
How deep is the recess? Most sockets are pretty similar in thickness. You may need to get one machined down a bit or get out the grinder
Posted: Wed Jul 10, 2013 2:00 pm
by buried
Recess is around 6mm deep, when done up the nut sits flush with the plate the oil filter screws down onto.
Contemplated getting one machined down but the only 36 i own is an impact socket and i'm not keen to weaken it considering i blew the side out of the previous one...
Posted: Wed Jul 10, 2013 2:16 pm
by Suza
get a tube socket cheap and nasty but thin walled, should be able to get one at a plumbing place
Posted: Wed Jul 10, 2013 3:03 pm
by mudlva
measure the external size and post it up then we will know if our gear would be of assistance
Posted: Wed Jul 10, 2013 3:25 pm
by buried
Am looking for a cheap thin walled one, problem is finding one - will try plumbing places, thanks suza.
Will see if i can get some measurements tonight, if not tomorrow morning as I wont be home till after dark tonight.
Posted: Wed Jul 10, 2013 3:34 pm
by mudlva
my 36mm socket measures 48mm o/d
Posted: Thu Jul 11, 2013 11:45 am
by buried
Posted: Thu Jul 11, 2013 6:20 pm
by tweake
you might have to get a bit of tube slightly smaller than the hole and bigger than the distance across the flats. cut out bits for the corners, so it slide over the nut and contacts the sides.
ie tube has a couple of tabs. sticking down that contact the sides.
should work if its not on super tight.
if you have a welder put some flat on each side and weld them to a tube.
Posted: Thu Jul 11, 2013 6:46 pm
by buried
If I had a welder, life would be so much easier haha
Found one that's 47mm OD, seems I had to pull it out again i'll take it in and see if it will slide in. Failing that I think its goin to be off to an engineer to machine down the end of the impact socket
Posted: Thu Jul 11, 2013 9:04 pm
by mudlva
go buy the thin wall cheapy and grind it down with an angle grinder
may even make some form of bolt type clamp and put it in the drill press, turning at slowest speed and use the angle grinder to trim the surface to suit.
i have done this on other tools and it can work quite well.
it will save destroying your decent 36mm socket.
then write on it S/T #36b for future referance
where abouts in AK are you??
Posted: Fri Jul 12, 2013 1:12 pm
by buried
I'm on the shore, will be trying the 47mm one tomorrow morning if its close i'll buy it and take to it with the grinder its only $30.
I contemplated making something but not having a welder and limited metal working tools makes it a bit difficult.
Posted: Fri Jul 19, 2013 10:51 am
by buried
Alright, just incase anyone else comes across this issue - apparently supercheap can order in a 36mm 12point socket with an OD of 41mm.
I ended up buying and bending a big screwdriver and removing some crap from the inner guard and bashing it around till it went down tight enough
