Advice on fitting hyd bump stops
- Dr. Love Glove
Help wanted from anyone with some experance in this job
Re: Advice on fitting hyd bump stops
Contact Tomsoffroad, he uses them quite often by the looks
Batfastard wrote:Help wanted from anyone with some experance in this job
What do you want to know?
Yeah, bit vague there bro. There will be heaps of people on here with experience, but you need to be a little more specific.
- Dr. Love Glove
Im fitting them on my rangerover . What a misson. Not alot of room got the front ones sorted .but had to weld some plates on the radious arms .as i have a twin shock set up .was not able to have them bump on the diff houseing . Now for the rear .will have same problem as twin shocks on rear and ive shortend the chassis and still want to mount a rear sway bar.may have to fab up some sort of a twin shock/ bump stop/swaybar mount .a three way bracket.its a shame i just cant pop down to repco to get one .as the list off jobs just seem to be getting longer.
Will they not fit in the spring ?
- Dr. Love Glove
QUADRACER wrote:Will they not fit in the spring ?
Where would the shock go then ......no point moving the shock to fit a bump stop in its place
