Vitara Clutch adjustment
Posted: Mon Jul 15, 2013 10:15 am
Hey all
Another question
On the weekend I changed my G/Box and T/Case fluid. GL-4 75w90 with a bit of Moreys in there for good measure.
I thought I would adjust the clutch aswel because sometimes its hard to get into first when stopped.
Question is, when adjusting a clutch that's not stuffed, but not new, should you be tightening or loosening the cable?
I have borrowed this pic off auszookers that shows a vitara clutch adjuster at the end of its loosest adjustment.
I know I should have pedal free play but i can also get that up at the top of the clutch pedal.
Should I be loose like the pic of the other end of the scale or somewhere in the middle?
Any advise would be appreciated.
Another question
