LD28T Specialist
A place where Useful information on makes of 4wd is stored by Tech Authors.
Moderators: Steve_t647, Tech Authors
pmfaulkner
LD28T Specialist
Post by pmfaulkner »
Can any recommend a Diesel Turbo specialist either on the North Shore or Auckland familiar with Defender LD28's? Have an unburnt fuel issue! Much appreciated.
Crash bandicoot
Re: LD28T Specialist
Post by Crash bandicoot »
unburnt fuel means low compression.
time for some new rings or a bent rod.
probably morrison diesel in onehunga would my pick
smurf182
Post by smurf182 »
Crash bandicoot wrote:unburnt fuel means low compression.
Steady on there, before I pulled a motor down for blowing a bit of black smoke, I would be checking for intake blockage (air filter), turbo function if its an ld28t, injector pump adjustment, injector performance and valve adjustment.
Crash bandicoot
fair enough call. but on the basis that diesel burns on compression the only other one to figure would be a bad valve which would be a pull down job anyway.
sibainmud
Post by sibainmud »
Alltech, dude. Wairau Road. Bloody good at that sort of thing and they have their own workshop which is not that common for a fuel specialist.
Heath
Post by Heath »
sibainmud wrote:Alltech, dude. Wairau Road. Bloody good at that sort of thing and they have their own workshop which is not that common for a fuel specialist.
Seconded!!
Return to “Tech Section/Library”
