Terrano body lift
For all Nissan related topics
RJT
Terrano body lift
Post by RJT »
It may be just me being dumb but has anybody had issues with rear body mount bolt alignment when doing a body lift on Terrano? It seems that the body has shifted forward by about 5-10mm. All bolts are loose.
Cheers, Rhys.
2008 R51, 2.5TD. 265/70R17 R/T's, 1.5" Rancho lift, Ironman snorkel and Deluxe winch bar, SCA 12,000lb winch and 9" LED spotlights, Kings awning, Alpinestar roof box, GME TX3100 UHF.
kiwipete
Re: Terrano body lift
Post by kiwipete »
RJT wrote:It may be just me being dumb but has anybody had issues with rear body mount bolt alignment when doing a body lift on Terrano? It seems that the body has shifted forward by about 5-10mm. All bolts are loose.
Cheers, Rhys.
Check out (ie. search) for a post i did on my iody lift. You have to loosen the three bolts that hold this nut retainer as the factory bolts are tapered on the ends. Failing this, ring me tomorrow.
Ph 0212078472
