I'm doing a run of ground anchors for myself and some of the locals haven't got confirmed numbers yet but looks like there will be 2 or three extra up for sale
It's a copy of a well proven winch comp version... fixed welded design with an 8 degree spade, spade is 380mm long to the point and 240mm wide made from 6mm Bissalloy (alot stronger than mild steel) and welded with special alloy rods the rest is mild with the main arm out of 65x35x4 with 6mm braces on the corner of the arm and to the spade
Possiblilty of a galv finish
Price is materials + 1/5th
Will have a confirmed price as soon as the profile cutters get back to me
I'm doing this to use up stock from my workshop prior to closing shop this won't be repeated as I'm not spending another $300 for a packet of these rods!
If your interested PM (first in first served) me I'll let you know price when qoutes are back from the profile cutters
Cheers Reece
Ground Anchors
- catalystracing
Re: Ground Anchors
PM sent
Re: Ground Anchors
would be safe to say if you haven't got your number down by now you've missed out
Cheers Reece
Re: Ground Anchors
Hope I got in fast enough
Reece
Reece
Re: Ground Anchors
suzuki1k wrote:Hope I got in fast enough![]()
Reece
second on the list mate
