LSD Shims?
For all Nissan related topics
BogBoy
LSD Shims?
Post by BogBoy »
Hey all
After going though the search on here I cant find any info on were to get shims for a d21 lsd.
Can any one help?
Crash bandicoot
Re: LSD Shims?
Post by Crash bandicoot »
BogBoy
Re: LSD Shims?
Post by BogBoy »
Ha ha ha cant do that...
Mine didnt have a LSD from factory.
I put one in....
1992 d21 if that helps any one? :?
safaripete
Re: LSD Shims?
Post by safaripete »
come for drive to palmy i'll shim it up for you nice n tight :wink:
BogBoy
Re: LSD Shims?
Post by BogBoy »
safaripete wrote:come for drive to palmy i'll shim it up for you nice n tight :wink:
I knew you would pop up!!! Nothing beats a true welded locker!!!
Wana weld a winch onto it for me at the same time :lol: :wink:
charo249
Re: LSD Shims?
Post by charo249 »
Internal shims, clutch plates etc are interchangeable between most 4wd Nissan diffs. So if you can't find any Navara shims Safari or Terrano ones should fit. One extra each side and it will almost feel like it is locked - my truck doesn't feel like there is any give till you are going about 30 - 40kph on tarseal.
