Ex RNZAF Defender
Posted: Thu Jul 25, 2013 5:07 pm
by pmfaulkner
Hi Team,
New to this so go easy!
Brought an Ex RNZAF Defender a few months ago and have just got round to tidying her up as a daily driver.
It's a LD28 turbo conversion with the typical biff's and bangs expected from it's half a million km's!
Couple of things that I need to get sorted to get her back up and running are as follows and any help would be much appreciated,
1. At low speed it is pumping out white smoke but no problem at high speed, thinking a turbo issue/ injectors, have found a stuck wastegate which we are investigating.
2. Lack of air filter, the vehicle was sold with a round LR air cleaner but not fitted, any advice on sizing of air filter for an LD28 turbo, will the LR unit suffice?
As I said, a newbie to this and any help would be appreciated, i'm sure these things have been discussed in the past and apologies if covering old ground.
Looking forward to getting the ongoing project underway!!
Re: Ex RNZAF Defender
Posted: Thu Jul 25, 2013 5:09 pm
by rob-mu
I wonder how long it's been used with no air filter
Posted: Thu Jul 25, 2013 5:20 pm
by pmfaulkner
Sorry I should clarify there is a small filter but seems inadequate.
Posted: Thu Jul 25, 2013 5:25 pm
by basics
nice truck, and welcome to ORE
sorry i cant awnser any of your questions, some one will be along soon with some awnsers for you
Posted: Thu Jul 25, 2013 5:46 pm
by slidenyo
could use any filter really depends on your airbox etc,
ld28's often need attention around valve guide seals and valve stem wear,
mines the same white smoke till its up to temp and working
Posted: Thu Jul 25, 2013 9:37 pm
by RRS
You need a big air cleaner, I used a Donaldson out off a MF combine, probably an 8 or 10 inch. It can't be too big.
Air is still pretty cheap, and the more you use the better.
You also need an extra big exhaust.
Posted: Fri Jul 26, 2013 9:09 pm
by snotgoblin
She looks a lot different from the Defenders the RNZAF used. Colour, alloys, bullbar to name a few. And from memory ours were V8 too.
Looks very tidy in white though, nicer than the faded olive green it once was.
I am waiting for when we sell off our old Range Rover ambulances, reckon they would be great starting points for campers.
Posted: Fri Jul 26, 2013 9:16 pm
by Cameron
nice!
Saw that other one on trademe last night too!
cool wagon, dude.
Posted: Fri Jul 26, 2013 10:10 pm
by pmfaulkner
RRS wrote:You need a big air cleaner, I used a Donaldson out off a MF combine, probably an 8 or 10 inch. It can't be too big.
Cheers, the unit I have should do the trick, any recommendation on bore size of exhaust, it's looking like it is on it's last legs so an upgrade could be on the cards!
Posted: Fri Jul 26, 2013 10:29 pm
by nakimud
My thinking is the Kiki injector pump, with regards to timing and advance mechanism. I have a 110 and a s3 with an LD28, soon to be turbo, it uses the original oil bath filter. The stock V8 cooper air cleaner would be more than satisfactory for an LD28 Turbo, I ran my previous 110 with a GM 6.2 Diesel on one worked a charm
Posted: Fri Jul 26, 2013 10:31 pm
by nakimud
Nice Rig too, should get along nicely with the LD28t and 5 Speed box. Are those discovery mag wheels?
Posted: Sat Jul 27, 2013 11:01 am
by RRS
I think I used a 2.5 inch exhaust, you don't need much for a muffler.
Remember to use a flexijoint near the turbo.
I did this in the early nineties .
Also remember the original sump is tiny, but you keep the horsepower sensible you won't have any problems.
Mine was putting out about 160 hp and had every problem you can imagine.
You would be in trouble if you dumped clouds of black smoke at the lights now.
Posted: Sat Jul 27, 2013 12:46 pm
by bang-thud-thump
Posted: Sat Jul 27, 2013 2:28 pm
by BlakeNZ
Different wheels, no snorkel....
Posted: Sat Jul 27, 2013 5:35 pm
by Ralfie
different vehicle ............
RNZAF did happen to have more than one vehicle in their fleet.
Posted: Sat Jul 27, 2013 6:30 pm
by BlakeNZ
that was the point i was trying to suggest, though not clearly. sorry.
Posted: Sat Jul 27, 2013 7:22 pm
by pmfaulkner
nakimud wrote:Nice Rig too, should get along nicely with the LD28t and 5 Speed box. Are those discovery mag wheels?
Think they are discovery, thanks for the advice.
Posted: Sat Jul 27, 2013 7:24 pm
by pmfaulkner
RRS wrote:I think I used a 2.5 inch exhaust, you don't need much for a muffler.
Will try and keep it a fair bit tamer! Will look into the exhaust options
Posted: Thu Aug 01, 2013 10:07 pm
by pmfaulkner
New plugs and water pump on the way, olde smokey no more! Previous owner had breather from rocker into pressurized side of turbo!
Running like a dream, just need to decide on a man size air cleaner, the one shown is totally undersized! Just need to find some room, the current option is a bit on the large size to fit anywhere in the engine bay, any ideas? or smaller options?
Posted: Fri Aug 02, 2013 2:32 pm
by BlakeNZ
my ld28 in a landie 110 had a very similar/same filter housing as that big black cylindrical one in your photo. Possibly factory?
it was mounted at the front of the engine bay, on the drivers side.
Posted: Fri Aug 02, 2013 4:03 pm
by Ralfie
http://www.trademe.co.nz/motors/used-ca ... 258881.htmif you check out the engine bay photo on the sister vehicle then you will see the original canister type filter tucked away on the front.
Posted: Fri Aug 02, 2013 9:41 pm
by pmfaulkner
Ralfie wrote:http://www.trademe.co.nz/motors/used-cars/land-rover/110/auction-619258881.htm
Have tried that option but to tight unless we modify the guards.
Posted: Fri Aug 02, 2013 11:45 pm
by Ralfie
Is the canister air cleaner you have originally a V8 one that sat on top at the back of the engine?
If so its probably why its too big.
You may need to swap it for one from 4-cylinder, diesel or turbo diesel 90/110 and then it will fit.
Posted: Sat Aug 03, 2013 10:22 am
by noexitroad
looks like you got the v8 one there
