Lj78/kzj78 manual parts
rob-mu
Post by rob-mu »
Looking at throwing in a auto so will have the following bits for sale:
Manual bell housing 1kz
Solid flywheel +new(ish) clutch with brand new genuine bolts
R150f +transfer with a new shifter ball and bush
+all the other associated parts
Would be ideal to do a swap with someone wanting to convert to manual?
Rob
0275136680
kbushnz
Re: Lj78/kzj78 manual parts
Post by kbushnz »
you know the drive shafts are different between the auto and the manual and also the cross member is in a different place .
rob-mu
Post by rob-mu »
Thanks for the info Calvin .needed a custom front one anyway due to axle being moved forward And crossmember is no problem
Rob
kbushnz
Post by kbushnz »
Yeah the manual is shorter than the auto so the transfer case ends up in a different place Go figure !
rob-mu
Post by rob-mu »
Oh i see.
Looking forward to seeing your ute chop
imsohi
Post by imsohi »
Have a talk to Slide he is wrecking a auto one for his boss LJ71
sig
Jeep Jeep
Post by sig »
how much for the manual stuff
