ive got my 40 series in bits in the shed and im trying to sort through what i need and it seems i have alot of stuff taking up valuable space.
its all from a 1980 bj40 nz assembled 12v
so far up for grabs:
1b diesel,was turboed,will need attention and a injection pump.did run when parked up.plus spares
5 speed gearbox and transfer case,minus pto drive.
4 speed gearbox only,i.e no bellhousing etc.
spare transfer case in pieces
front diff minus locking hubs.
original steering box
full set of springs.
set of bilstein shocks that seem ok but need new bushes
both driveshafts and some spares.
chassis which has rust,mainly around rear spring hangers.
some tail lights.
boxes and boxes of odds and sods
if your after something ask and ill have a dig around and see if i have it.
im not going to list it on trademe at the moment.
pickup or sort your own freight.
if its still sitting there in a month or two its going to scrap
cheers tony
40 series garage sale.
Re: 40 series garage sale.
i just dug through the boxes of bits and heres what i found
drivetrain parts:
miscellaneous enigne gaskets might be one complete set and some double ups
2x engine oil filter housings
1x gearbox mount
thermostat housing
rear crank seal housing
complete driveshaft might be a rear plus a spare drive spline end
injector return rail
about 5 tie rod ends
rocker cover + rockers
steering relay box bush.genuine toyota
1 set of engine main bearings
1 set small end bearings
1x new rear transfer case seal
2 x needle roller bearings.genuine toyota p/n 90364-34006
1x c.v
1x stripped inline injection pump.only good for parts
1x gearbox input shaft. 10 spline
speedo drive incomplete
1x intake butterfly.
body parts:
heater tap
fuel flap
clutch master cylinder
brake master cylinder
a small bag of door latch parts
1x spare tail light.missing lense
electrical parts:
alternator pulley single v type
2x 12v starter relays
1x complete 12v starter
2x spare motors
1x voltage regulator
1x fuel control relay
1x alternator stator +brush holder.
drivetrain parts:
1x gearbox mount
thermostat housing
1x c.v
body parts:
heater tap
fuel flap
electrical parts:
2x spare motors
What was the 5 speed out off ?
A 60 series apparently.i was told its a h55f
2 weeks then its all going to scrap so speak up now if your after something.ill get bugger all at scrap but atleast its not in the way.
pm me or miss out
pm me or miss out
bump
still have the 5 speed that i need gone.
still has the pto unit on it.
$350 and its yours pm me if your keen.
need the cash to fund my projects.
could also be interested in selling the complete body(reg on hold no chassis) if someone is in the market for one.
- ClassicCruiserSpares
- Sausage Shack
Pm sent.
Doors and bonnet?
yeh mate body is complete but i want to keep it complete for now and in not much of a hurry to see it go.
theres a spare bonnet too.
the body is rough and has had some average repairs done over its lifetime and the body mounts under the seats are half rotten/gone.
doors have rust in the corners
keen on the Gboxes/case's if you still have them bro? my 40s Gbox/case is making some horrid noises after the 24hr race few weeks ago
box sold!!!
thank f***
now i can get a th350
thank f***
ok ive had a serious think about what im doing and where im at so far and ive come up with a solution to some of my problems.
but it means selling the body of the 40 and everything else 40 series that i have except the winch.
im not to keen to put it on trademe and get mucked around.so make me an offer.come have a look or pm me.
