wanted: safari/patrol lwb standard springs
hi, does anyone in the auckland area have a set of standard springs from a safari or patrol lwb that were not sagging to much when removed? thanks
Re: wanted: safari/patrol lwb standard springs
yea i got some, not sure if they are sagged, It sat level so probably arent to bad.
check out the "Before lift photo" on page 2 to see if there is any sag. Im out east if you keen. http://www.offroadexpress.co.nz/Forums/ ... 6&start=15
Also have no idea how much they worth so just make an offer. Just pulled them out a week ago. Im away for work for a few weeks so not on here to often at the moment, just txt/call if you keen. Cheers
92 LWB Safari TD42
your truck looks wicked, way better than standard height, is it lifted 2 or 3 inches? the old springs dont look stuffed to me, what are you wanting for them? cheers
its a 60mm lift with 33's, really happy with how its turnned out thanks
92 LWB Safari TD42
