AGGGGGGGGHHHHHHHHHHH!!!!!!!!!!!!!!!!!!!
For all Nissan related topics
BogBoy
Post by BogBoy »
Can some one tell me the easy way to remove the front diff from a D21 :cry:
poss682
Re: AGGGGGGGGHHHHHHHHHHH!!!!!!!!!!!!!!!!!!!
Post by poss682 »
have you slid-en the stub axles out ?
BogBoy
Post by BogBoy »
poss682 wrote:have you slid-en the stub axles out ?
You mean unbolted them....
I have unbolted the whole unit but now its stuck half hanging against the sump.
Cant drop the front cross member as I cant get two of the bolts out (stuck behind lower arm/torsion bar end)
I was thinking about unbolting the engine and jacking it straight up but then that would tip it at a angle.
I thought this would be easy :lol:
keithal
Post by keithal »
BogBoy wrote:I thought this would be easy :lol:
a gas axe would cut it out quite easily :lol: :lol:
BogBoy
Post by BogBoy »
Dont temp me...... :lol:
Fast track the SAS....
firestonecruiser
Post by firestonecruiser »
if u lower the height by the torsion bars so it is sitting on its arse, removed the 3 nuts on the spline end of torsion bar which i guess is the ones u cant get out. slide the cover back over the torsion bar and drop them right out.
rob-mu
Post by rob-mu »
What a shit subject name
Rob
BogBoy
Post by BogBoy »
Na its past the torsion bars already. its catching on the stupid sump
BogBoy
Post by BogBoy »
rob-mu wrote:What a shit subject name
Rob
Awww it took me ages to think of it!!! :lol:
slide
Post by slide »
Of the four bolts that hold crossmember in, two can't be removed :? :evil: . Easiest way to remove diff is to cut these suckers (just enough room to get angle grinder in there). Then get two new bolts and fit them from front ensuring there's enough clearance at back for suspension not to foul.
I took sibainmuds advice here, and its definately worth while. Means you can remove at later date without hassles too 8)
Nath
BogBoy
Post by BogBoy »
slide wrote:Of the four bolts that hold crossmember in, two can't be removed :? :evil: . Easiest way to remove diff is to cut these suckers (just enough room to get angle grinder in there). Then get two new bolts and fit them from front ensuring there's enough clearance at back for suspension not to foul.
Nath
Sounds like a great idea to me!!! the ones that sit behind the arms have been cross threaded so were a pain in the ass to get off.
Will keep you up dated on how I go as I want to replace some other bolts due to rust/damage.
:D
snatch22
Post by snatch22 »
Nath
this is exactly what i did so i could get the motor out to do the clutch...would be real great if you could just undo the front body mounts and lift the body like a bonnet haha
