LPG any use with these 2.7 diesels
Posted: Sun Jul 28, 2013 11:08 pm
by philip121
anyone had a diesel run on LPG would it be better than RUG costs
Re: LPG any use with these 2.7 diesels
Posted: Mon Jul 29, 2013 12:03 am
by BlakeNZ
excuse my ignorance... how do you run a diesel motor on lpg?
The massive compression of a diesel motor will not like the high octane of LPG. Won't it go BANG!!!?
Posted: Mon Jul 29, 2013 12:25 am
by philip121
with the bang as you put it the engine would turn over
Posted: Mon Jul 29, 2013 5:49 am
by tallsam66
You cant use LPG in place of diesel in a diesel motor ...it will destroy it.
LPG will only work in a petrol engine.
Posted: Mon Jul 29, 2013 7:24 am
by rokhound
Posted: Mon Jul 29, 2013 7:47 am
by uptomynutsinruts
Hahahahahah Thats fucken awesome
Posted: Mon Jul 29, 2013 8:02 am
by wax
You do a conversion
http://www.dieselgasaustralia.com.au/de ... tallationshttp://www.autospeed.com.au/cms/A_112610/article.htmlSome times its better to keep mouth closed and be thought of as a fool than to open it and remove all doubt
Posted: Mon Jul 29, 2013 8:18 am
by kbushnz
Those convertions and really mods. As it only introduces LPG into the combustion process of the diesel.. Fumigation.. It still needs diesel to run.
To use LPG to replace diesel as a fuel in a diesel engine wont work.
http://www.go-lpg.co.uk/diesel.html
Posted: Mon Jul 29, 2013 8:57 am
by CLUMZ1
Posted: Mon Jul 29, 2013 9:54 am
by Swamped
Posted: Mon Jul 29, 2013 12:01 pm
by rokhound
I just knew someone would bring that back into this
Posted: Mon Jul 29, 2013 3:30 pm
by NJV6
Yes, this works. For every 10 litres of LPG you put in, I always make sure I mix it with the same amount of water for my farm hilux, it raises the compression ratio which gives a bigger bang, more power
. You get a double bonus with adding the water, almost makes half the mileage free unless you buy pump bottles but that's a dear way of doing it.
Posted: Mon Jul 29, 2013 3:58 pm
by Jerry
you lot are just being silly
you just need to plumb in a 9kg bbq bottle
CNG was big in the 80's .... maybe thats worth a look
Posted: Mon Jul 29, 2013 5:24 pm
by stinky
I have 2 lpg bottles hooked up in my new truck its a 3.3 diesel lpg works well not had any problems yet
Posted: Mon Jul 29, 2013 5:38 pm
by MikeL200
From Aust 4WD Action forum:
12H-T on gas FOR THE WIN.
I have a basic fumigation setup on mine (installed 7 yrs ago at 240k now 320k) by Torquegas into the induction pipe. It picks up vapour from the 20L tank (where spare tyre used to be) with a converter for safety and small manual adjustment. Triggered by 0.5 psi by hobbs switch - draws more gas as revs and load increases.
Since LPG i've added a big dump pipe & 3 inch exhaust, 14 psi, external pump tweaks and front mounted air to air 'cooler. Max 500 deg post turbo.
The LPG which can be turned on/off is brilliant and very noticeable. Holds gear up hills big time.
City/h'way cycle is around 12L diesel & 3L gas.
Bang for buck - my setup was 3K and i scored the 2K gov refund - great value but 5K for a dgas system..... maybe not.
